9 years agocyclone5 gt and ddrin 400 Mhz for adc acquisition
Hi to hall.
I'm trying to connect an ADC (ads5263) to a FPGA (cyclone 5 GT dev board). The ADC has for each channel (4 channels in total) 2 lvds outputs and a bit clock of 400 MHz DDR. So working on 100MSPS 16 bits will 800Mbps x 2 outputs = 1.6 Gbps. The bit clock (400 MHz DDR) is center-aligned with the data of the 2 outputs. The Tsu and Th of the adc is respectively: 0.23ns and 0.31 ns. Reading the various documents I calculated the max and min delays related to the launch of virtual clock (that is 90 degrees in advance with respect to the latch clock supplied from the ADC): default_tsu (@ 400MHz DDR) = 0.625 ns. default_th (@ 400MHz DDR) = 0.625 ns. tmax = default_tsu - t_su (ADC) = 0.625 - 0.23 = 0.395ns tmax = 0.395ns tmin = - (default_h - t_h (ADC) = 0.625 - 0.31 = - (0.315ns) tmin = -0.315ns I set the input_delay as follows: # ************************************************* *************# time information# ************************************************* *************
set_time_format -unit ns -decimal_places 3
# ************************************************* *************# create clock# ************************************************* *************
create_clock -name {adc_bit_clk} -period 2.500 [get_ports {adc_bit_clk}]
create_clock -name {launch_bit_clk} -period 2.500 -waveform {1.875 3.125}
# **************************************************************# set input delay# **************************************************************
set_input_delay -add_delay -clock { launch_bit_clk } -max 0.395 [get_ports {adc_ch* adc_frm_clk}]
set_input_delay -add_delay -clock { launch_bit_clk } -clock_fall -max 0.395 [get_ports {adc_ch* adc_frm_clk}]
set_input_delay -add_delay -clock { launch_bit_clk } -min -0.315 [get_ports {adc_ch* adc_frm_clk}]
set_input_delay -add_delay -clock { launch_bit_clk } -clock_fall -min -0.315 [get_ports {adc_ch* adc_frm_clk}]
# set false paths to remove irrelevant setup and hold analysis
set_false_path -fall_from [get_clocks launch_bit_clk] -rise_to [get_clocks {adc_bit_clk}]
-setup
set_false_path -rise_from [get_clocks launch_bit_clk] -fall_to [get_clocks {adc_bit_clk}]
-setup
set_false_path -fall_from [get_clocks launch_bit_clk] -fall_to [get_clocks {adc_bit_clk}]
-hold
set_false_path -rise_from [get_clocks launch_bit_clk] -rise_to [get_clocks {adc_bit_clk}]
-hold All signals are lvds, optimizations fitter at most. But unfortunately timequest analysis fails. According to you experts, there is a way to capture the data from the adc ads5263 at 400Mhz DDR of cyclone 5, using megafunction alt_ddio? I also enclose a list of the pin settings used on cyclone5 GT dev board: set_global_assignment -name family "cyclone v"
set_global_assignment -name device 5cgtfd9e5f35c7
set_global_assignment -name top_level_entity top_adc_sample
set_global_assignment -name original_quartus_version 16.0.0
set_global_assignment -name project_creation_time_date "14:55:45 december 05, 2016"
set_global_assignment -name last_quartus_version 16.0.0
set_global_assignment -name project_output_directory output_files
set_global_assignment -name min_core_junction_temp 0
set_global_assignment -name max_core_junction_temp 85
set_global_assignment -name device_filter_pin_count 1152
set_global_assignment -name error_check_frequency_divisor 256
set_global_assignment -name eda_simulation_tool "modelsim (vhdl)"
set_global_assignment -name eda_time_scale "1 ps" -section_id eda_simulation
set_global_assignment -name eda_output_data_format vhdl -section_id eda_simulation
set_global_assignment -name vhdl_file top_adc_sample.vhd
set_global_assignment -name partition_netlist_type source -section_id top
set_global_assignment -name partition_fitter_preservation_level placement_and_routing -section_id top
set_global_assignment -name partition_color 16764057 -section_id top
set_instance_assignment -name global_signal off -to adc_frm_clk
set_global_assignment -name sdc_file adc_sample.sdc
set_global_assignment -name power_preset_cooling_solution "23 mm heat sink with 200 lfpm airflow"
set_global_assignment -name power_board_thermal_model "none (conservative)"
set_global_assignment -name qip_file ddio1.qip
set_global_assignment -name timequest_multicorner_analysis on
set_global_assignment -name disable_ocp_hw_eval on
set_location_assignment pin_h17 -to adc_bit_clk
set_instance_assignment -name io_standard lvds -to adc_bit_clk
set_instance_assignment -name input_termination differential -to adc_bit_clk
set_location_assignment pin_f17 -to adc_frm_clk
set_instance_assignment -name io_standard lvds -to adc_frm_clk
set_instance_assignment -name input_termination differential -to adc_frm_clk
set_location_assignment pin_m16 -to adc_ch1_a
set_instance_assignment -name io_standard lvds -to adc_ch1_a
set_instance_assignment -name input_termination differential -to adc_ch1_a
set_location_assignment pin_b8 -to adc_ch1_b
set_instance_assignment -name io_standard lvds -to adc_ch1_b
set_instance_assignment -name input_termination differential -to adc_ch1_b
set_location_assignment pin_h16 -to "adc_bit_clk(n)"
set_location_assignment pin_f16 -to "adc_frm_clk(n)"
set_location_assignment pin_l17 -to "adc_ch1_a(n)"
set_location_assignment pin_a8 -to "adc_ch1_b(n)"
set_global_assignment -name optimization_mode "aggressive performance"
set_instance_assignment -name global_signal off -to adc_ch1_b
set_instance_assignment -name global_signal off -to adc_ch1_a
set_global_assignment -name optimize_multi_corner_timing off
set_global_assignment -name io_placement_optimization on
set_instance_assignment -name partition_hierarchy root_partition -to | -section_id top Best regards.
No way with ddio_in function.
I can respect the timequest analysis only if i use the lvdsrx megafunction, using the true lvds receivers of cyclone5. Best regards - Altera_Forum
No, i do not agree. You have wrong relationship between launch and latch clocks. See picture from datasheet : https://www.alteraforum.com/forum/attachment.php?attachmentid=13019 Your relationship should look like: https://www.alteraforum.com/forum/attachment.php?attachmentid=13020 Maybe I am wrong, this is from quick glance in to datasheet. Correct your base and virtual clock constraints that they have correct relationship. Correct false path exceptions and post your waveform from TimeQuest. - Altera_Forum
--- Quote Start --- Hi, In my opinion you have entered wrong false path exceptions. You are saying that data is launched by rising edge of virtual clock LAUNCH_BIT_CLK (which is phase shifted +90 deg.), this means that you are latching data with falling edge of ADC_BIT_CLK. So you have to cut paths between same edge transfers in setup and between different edge transfers in hold. Also I think you should use PLL in your design, which will help to meet timing in your design. Regards. --- Quote End --- Hi vlrean! My false path exceptions, I think they are correct (see image). The launch is at rising and the latching is at rising. Then the false path is from rising to falling for setup (et vice-versa), and from rising to rising(and falling to falling) for hold. do you agree? - Altera_Forum
