9 years agocyclone5 gt and ddrin 400 Mhz for adc acquisition
Hi to hall. I'm trying to connect an ADC (ads5263) to a FPGA (cyclone 5 GT dev board). The ADC has for each channel (4 channels in total) 2 lvds outputs and a bit clock of 400 MHz DDR. So w...
9 years agoHi,
In my opinion you have entered wrong false path exceptions. You are saying that data is launched by rising edge of virtual clock LAUNCH_BIT_CLK (which is phase shifted +90 deg.), this means that you are latching data with falling edge of ADC_BIT_CLK. So you have to cut paths between same edge transfers in setup and between different edge transfers in hold. Also I think you should use PLL in your design, which will help to meet timing in your design. Regards.
