11 years ago
Cyclone V PCIE Hard IP
We want use pcie Configuration via Protocol, but we are confused with the pcie reset controller.
which pin can be used for pcie_npor_npor and pcie_npor_pin_perst?
if use the CvP function, is it a must to use hard reset controller ?
Please help!!!
    --- Quote Start ---
    The info in CvP user guide "...use the nPERSTL1 for the reset controller." is correct.
    The info in Cyclone V PCIe user guide ' NPERSTL0: bottom left Hard IP and CvP blocks" is a typo. The correction is " ' NPERSTL1: bottom left Hard IP and CvP blocks""
    --- Quote End ---
    Thanks for the clarification. I came to the same conclusion after compiling a CvP design in Quartus 14.
    Please note that the NPERST mapping for Cyclone V is opposite for Stratix V and Arria V (where bottom HIP is associated with nPERSTL0, top HIP is associated with nPERSTL1).
    The correct mapping for Cyclone V is:
    TOP PCIe HIP --> nPERSTL0
    BOTTOM PCIe HIP --> nPERSTL1
    I'm presently checking if CvP might be enabled in a Cyclone V GX PCIe design of 2012 by pure code redesign, of if hardware changes could be necessary.
    --- Quote Start ---
    For Cyclone V device, you need to use the nPERSTL1 for the reset controller.
    --- Quote End ---
    That's in fact written in the CvP user guide. But the Cyclone V specific PCIe user guide tells:
    --- Quote Start ---
    • NPERSTL0: bottom left Hard IP and CvP blocks
    • NPERSTL1: top left Hard IP block
    • NPERSTR0: bottom right Hard IP block
    • NPERSTR1: top right Hard IP block
    For example, if you are using the Hard IP instance in the bottom
    left corner of the device, you must connect pin_perst to
    NPERSL0.
    For maximum use of the Cyclone V device, Altera recommends
    that you use the bottom left Hard IP first. This is the only
    location that supports CvP over a PCIe link. If your design does
    not require CvP, you may select other Hard IP blocks.
    --- Quote End ---
    This sounds more reasonable because NPERSTL0 is assigned to the bottom left PCIe hard IP incorporating the CVP function. It's also the configuration provided by the Altera Cyclone V GX FPGA Dev Kit. Unless someone can give a good explanation for the statement in the CvP user guide, I presume it's a typo.
    To ask a subsequent question, did somebody already implement CvP with Cyclone V GX and can comment about correctness of the documentation.
    Another simple question, I have been using Quartus 13.1 up to now, it tells me "CvP not supported for Cyclone V" when I try to enable it in the device configuration. Is it so that Cyclone V CvP requires Quartus 14 or did I anything (not obviously) wrong?
    Frank
    Hi kerb,
    Yes, if you use CvP function, is it a must to use hard reset controller. By default PCIe core is using hard reset controller.
    There is a dedicated HIP that support this CvP feature which is the bottom left HIP. Other HIP does not support CvP. For Cyclone V device, you need to use the nPERSTL1 for the reset controller. You can refer to the CVP user guide and Cyclone V PCIe user guides either in Avalon ST or Avalon MM from these links:
    https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_cvp.pdf
    https://www.altera.com/en_us/pdfs/literature/ug/ug_c5_pcie_avst.pdf
    https://www.altera.com/en_us/pdfs/literature/ug/ug_c5_pcie_avmm.pdf
    If I understand it correctly, the perst pin is dedicated pin available in the device. If you create the hard IP and let Fitter auto fit, it should select the dedicated pin.
