11 years agoCyclone V PCIE Hard IP
We want use pcie Configuration via Protocol, but we are confused with the pcie reset controller. which pin can be used for pcie_npor_npor and pcie_npor_pin_perst? if use the CvP function, is...
11 years agoThere is a dedicated HIP that support this CvP feature which is the bottom left HIP. Other HIP does not support CvP. For Cyclone V device, you need to use the nPERSTL1 for the reset controller. You can refer to the CVP user guide and Cyclone V PCIe user guides either in Avalon ST or Avalon MM from these links:
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_cvp.pdf https://www.altera.com/en_us/pdfs/literature/ug/ug_c5_pcie_avst.pdf https://www.altera.com/en_us/pdfs/literature/ug/ug_c5_pcie_avmm.pdf
