11 years agoCyclone V PCIE Hard IP
We want use pcie Configuration via Protocol, but we are confused with the pcie reset controller. which pin can be used for pcie_npor_npor and pcie_npor_pin_perst? if use the CvP function, is...
11 years agoI'm presently checking if CvP might be enabled in a Cyclone V GX PCIe design of 2012 by pure code redesign, of if hardware changes could be necessary.
--- Quote Start --- For Cyclone V device, you need to use the nPERSTL1 for the reset controller. --- Quote End --- That's in fact written in the CvP user guide. But the Cyclone V specific PCIe user guide tells: --- Quote Start --- • NPERSTL0: bottom left Hard IP and CvP blocks • NPERSTL1: top left Hard IP block • NPERSTR0: bottom right Hard IP block • NPERSTR1: top right Hard IP block For example, if you are using the Hard IP instance in the bottom left corner of the device, you must connect pin_perst to NPERSL0. For maximum use of the Cyclone V device, Altera recommends that you use the bottom left Hard IP first. This is the only location that supports CvP over a PCIe link. If your design does not require CvP, you may select other Hard IP blocks. --- Quote End --- This sounds more reasonable because NPERSTL0 is assigned to the bottom left PCIe hard IP incorporating the CVP function. It's also the configuration provided by the Altera Cyclone V GX FPGA Dev Kit. Unless someone can give a good explanation for the statement in the CvP user guide, I presume it's a typo. To ask a subsequent question, did somebody already implement CvP with Cyclone V GX and can comment about correctness of the documentation. Another simple question, I have been using Quartus 13.1 up to now, it tells me "CvP not supported for Cyclone V" when I try to enable it in the device configuration. Is it so that Cyclone V CvP requires Quartus 14 or did I anything (not obviously) wrong? Regards, Frank
