11 years agoCyclone V PCIE Hard IP
We want use pcie Configuration via Protocol, but we are confused with the pcie reset controller. which pin can be used for pcie_npor_npor and pcie_npor_pin_perst? if use the CvP function, is...
11 years ago --- Quote Start --- The info in CvP user guide "...use the nPERSTL1 for the reset controller." is correct. The info in Cyclone V PCIe user guide ' NPERSTL0: bottom left Hard IP and CvP blocks" is a typo. The correction is " ' NPERSTL1: bottom left Hard IP and CvP blocks"" --- Quote End --- Thanks for the clarification. I came to the same conclusion after compiling a CvP design in Quartus 14.
