11 years agoCyclone V PCIE Hard IP
We want use pcie Configuration via Protocol, but we are confused with the pcie reset controller. which pin can be used for pcie_npor_npor and pcie_npor_pin_perst? if use the CvP function, is...
11 years agoHi,
If I understand it correctly, the perst pin is dedicated pin available in the device. If you create the hard IP and let Fitter auto fit, it should select the dedicated pin.
