9 years agoCyclone V, HPS SPI routing to FPGA pins
Hello everyone,
I'm using the DE0-Nano Soc Board and tried to route the signals of the HPS SPI Master Peripheral to FPGA Pins. In Qsys i activated the SPI Master and set the pins to FPGA. In top_level entity they are connected to fpga pins. The problem is, that the Fitter isn't able to route the sclk signal to the fpga pin i have assigned. When i don't assign a pin, the fitter can place it to some pin locations. With assigned pins i get the following error messages.
Error (175020): The Fitter cannot place logic auto-promoted clock driver that is part of Arria V/Cyclone V Hard Processor System soc_system_hps_0 in region (28, 8) to (68, 61), to which it is constrained, because there are no valid locations in the region for logic of this type.
Info (14596): Information about the failing component(s):
Info (175028): The auto-promoted clock driver name(s): soc_system:qsys_system|soc_system_hps_0:hps_0|soc_system_hps_0_fpga_interfaces:fpga_interfaces|spim0_sclk_out~CLKENA0
Error (16234): No legal location could be found out of 30 considered location(s). Reasons why each location could not be used are summarized below:
Error (15123): The following auto-promoted clock driver locations cannot route to all the required pins
Info (175027): Destination: pin fpga_spi0_sclk
Info (175015): The I/O pad fpga_spi0_sclk is constrained to the location PIN_AE12 due to: User Location Constraints (PIN_AE12)
Info (14709): The constrained I/O pad is contained within this pin
Info (175029): 11 locations affected
Info (175029): CLKCTRL_R0
Info (175029): CLKCTRL_R2
Info (175029): CLKCTRL_R4
Info (175029): CLKCTRL_R6
Info (175029): CLKCTRL_R8
Info (175029): CLKCTRL_R70
Info (175029): CLKCTRL_R72
Info (175029): CLKCTRL_R74
Info (175029): CLKCTRL_R76
Info (175029): CLKCTRL_R78
Info (175029): CLKCTRL_R80
Info (175013): The auto-promoted clock driver is constrained to the region (28, 8) to (68, 61) due to related logic
Info (175015): The HPS_INTERFACE_PERIPHERAL_SPI_MASTER soc_system:qsys_system|soc_system_hps_0:hps_0|soc_system_hps_0_fpga_interfaces:fpga_interfaces|peripheral_spim0 is constrained to the location HPSINTERFACEPERIPHERALSPIMASTER_X32_Y44_N111 due to: User Location Constraints (HPSINTERFACEPERIPHERALSPIMASTER_X32_Y44_N111)
Info (14709): The constrained HPS_INTERFACE_PERIPHERAL_SPI_MASTER drives this auto-promoted clock driver
Error (175006): Could not find path between source HPS_INTERFACE_PERIPHERAL_SPI_MASTER and the auto-promoted clock driver
Info (175026): Source: HPS_INTERFACE_PERIPHERAL_SPI_MASTER soc_system:qsys_system|soc_system_hps_0:hps_0|soc_system_hps_0_fpga_interfaces:fpga_interfaces|peripheral_spim0
Info (175021): The HPS_INTERFACE_PERIPHERAL_SPI_MASTER was placed in location HPSINTERFACEPERIPHERALSPIMASTER_X32_Y44_N111
Error (175022): The auto-promoted clock driver could not be placed in any location to satisfy its connectivity requirements
Info (175029): 19 locations affected
Info (175029): CLKCTRL_G12
Info (175029): CLKCTRL_G13
Info (175029): CLKCTRL_G14
Info (175029): CLKCTRL_G15
Info (175029): CLKCTRL_R1
Info (175029): CLKCTRL_R3
Info (175029): CLKCTRL_R5
Info (175029): CLKCTRL_R9
Info (175029): CLKCTRL_G8
Info (175029): CLKCTRL_G9
Info (175029): CLKCTRL_G10
Info (175029): and 7 more locations not displayed
I think that there are some restrictions which pins the peripherals of the hps can access in the fpga region, but i wasn't able to find something about it in the device handbook. It's also possible that i haven't the right settings in my project, so have sombody else succesfully placed the spi signals in the fpga region and can give me some tips? Best regards Bjoern4 Replies
Just had the same issue (w/ Q16.1) and that did the trick. Thanks for the heads-up on this.
--- Quote Start --- Hello Captain-Chaos, I'm facing the same problem while exporting the spi_clk hps signal to fpga and got this error. Did you managed to solve it? I used the workaround posted but the error is still there. --- Quote End --- Hey, in my Design the solution with an boolean combinational function works fine. Did you try this or the maual LUT instantiation? AN706 (https://www.altera.com/documentation/mwh1410561892049.html) describes the reqired steps to export the perihperals, have you checked that there is no fault in your design? - Altera_Forum
I'm facing the same problem while exporting the spi_clk hps signal to fpga and got this error. Did you managed to solve it? I used the workaround posted but the error is still there. - Altera_Forum
I have send an Service Request to Altera and got an answer today.
It seems to be a bug in the quartus software, and the workaround is described here: https://www.altera.com/support/support-resources/knowledge-base/solutions/rd10132014_244.html Maybe this solution helps someone else in the future.
