9 years agoCyclone V, HPS SPI routing to FPGA pins
Hello everyone, I'm using the DE0-Nano Soc Board and tried to route the signals of the HPS SPI Master Peripheral to FPGA Pins. In Qsys i activated the SPI Master and set the pins to FPGA. In ...
9 years ago --- Quote Start --- Hello Captain-Chaos, I'm facing the same problem while exporting the spi_clk hps signal to fpga and got this error. Did you managed to solve it? I used the workaround posted but the error is still there. --- Quote End --- Hey, in my Design the solution with an boolean combinational function works fine. Did you try this or the maual LUT instantiation? AN706 (https://www.altera.com/documentation/mwh1410561892049.html) describes the reqired steps to export the perihperals, have you checked that there is no fault in your design?
