CYCLONE V - HPS and I2C Peripheral Pin
Hi Community
I'm testing the I2C interface embedded in CycloneV - HPS.
- However, if I export peripherals signals through the HPS I/O Set everything works pretty well.
- But If I switch to FPGA: exporting signals to FPGA Fabric (integarting them with suitable I/O Tristate buffers) the I2C protocol is completely different, the frequency of I2C signals passes from 100kHx to 6 kHz, and even if SDA seems in a certain way coherent with data, SCL is not.
Please note the different behavior in the images attached.
Any help will be appreciated!
- tehjingy_Altera
Hi
Any update on this case?
Did adding a pull up resistor solved the issue?
Jingyang, Teh
- StefanoMarsi
I tried both with external Pull-Up resistors (included in the client) and adopting PU in the pads, but the result is the same.
However please note my previous messages concerning the different behavior of the different peripherals i2c0 and i2c1 ! - tehjingy_Altera
Hi Stefano
Thanks for your testing.
After discussing we are suspecting either it is the i2c hard IP or the HPS-to-FPGA interface that could be the problem.
Below is the data flow of the signal.
Bolded are the part that we are currently suspecting.
HPS I2C Hard IP >> HPS-to-FPGA interface >> FPGA fabric >> FPGA I/O >> Level Shifter >> I2C slave
Is it possible if you could SignalTap the signals of the i2c signals for the setup you have for i2c0 and i2c1?
i2c1_out_scl
i2c1_out_sda
i2c1_in_scl
i2c1_in_sda
arm_a9_hps_i2c1_out_data
arm_a9_hps_i2c1_sda
arm_a9_hps_i2c1_clk_clk
arm_a9_hps_i2c1_scl_in_clk
GP0GPIO[0]
GP0GPIO[1]
Jingyang, Teh
- StefanoMarsi
- StefanoMarsi
- tehjingy_Altera
Hi Stefano
From the signal tap pictures that you send it seems like the problem could due to be originating between the HPS I2C Hard IP and HPS-to-FPGA interface.
This is not fixable by any software patch at the moment if the problem is coming from the HPS I2C Hard IP to the FPGA interface.
Are you seeing this behavior on other boards as well?
Jingyang, Teh
- tehjingy_Altera
Hi Stefano
Do you have an update for this?
Any chance that you are seeing this behavior on other boards as well?
Jingyang, Teh
- StefanoMarsi
I check on a different board and the results are the same !
- tehjingy_Altera
Hi Stefano
Please bear with me while I discuss with the engineering team.
Jingyang, Teh
- tehjingy_Altera
Hi Stefano
Due to the year end festivals, a lot of my colleagues are on leave hence the slow response.
Sorry, I still got no update on this case as of now.
Jingyang, Teh
- tehjingy_Altera
Hi Stefano
There is an internal case number that was created to track this issue.( 15014617860 )
The engineering team will be taking a look at this. They will not be able to provide a patch anytime soon.
Is it okay if we close this case since that the HPS i2c Signal is okay when it is on the dedicated IO instead of through the FPGA fabric?
Jingyang, Teh
- tehjingy_Altera
Hi
Since this thread been resolve, I shall set this thread to close pending. If you still need further assistance, you are welcome reopen this thread within 20days or open a new thread, some one will be right with you. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 4 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang, Teh
