CYCLONE V - HPS and I2C Peripheral Pin
Hi Stefano
Thanks for your testing.
After discussing we are suspecting either it is the i2c hard IP or the HPS-to-FPGA interface that could be the problem.
Below is the data flow of the signal.
Bolded are the part that we are currently suspecting.
HPS I2C Hard IP >> HPS-to-FPGA interface >> FPGA fabric >> FPGA I/O >> Level Shifter >> I2C slave
Is it possible if you could SignalTap the signals of the i2c signals for the setup you have for i2c0 and i2c1?
i2c1_out_scl
i2c1_out_sda
i2c1_in_scl
i2c1_in_sda
arm_a9_hps_i2c1_out_data
arm_a9_hps_i2c1_sda
arm_a9_hps_i2c1_clk_clk
arm_a9_hps_i2c1_scl_in_clk
GP0GPIO[0]
GP0GPIO[1]
Jingyang, Teh
- StefanoMarsi2 years ago
Thank you for your suggestion
I made the test you asked but the results are more or less the same I have on the oscilloscope at each level.
