17 years agoCyclone III EPCS16 config FAIL
Hi all,
I'm working on a revision of a PCB that contains a total of 12 EP3C16Q240C8N all configured with the same object file as in figure 10-6 of the datasheet. As it stands now, the configuration never succeeds (continually repeats and fails). Something that seems odd to me is that CONF_DONE briefly starts to rise before nSTATUS gets pulled low, restarting the cycle. I uploaded the image as CONF_DONE-and-nSTATUS.jpg The top (yellow) trace is CONF_DONE and the bottom (blue) is nSTATUS. Is this typical of a failed config? I have the DATA and DCLK lines buffered as follows: the EPCS feeds the master FPGA directly along with a pair of buffers. Each of these buffers then feeds a pair of slave devices and another set of buffers, which feeds another pair, and so on, up to a maximum of three buffers in the signal chain. I did things this way, up to two buffers in the signal chain in my first revision and after some initial struggle, now have no configuration issues with that board. As far as I can tell with my 200MHz scope, the signal looks pretty good, even at the end of the chain. I've uploaded the image as data_and_clock.jpg Perhaps someone with more experience in this department will have a different opinion? What does anyone suggest for a debugging methodology? I'm thinking of starting to break the nSTATUS and CONF_DONE connections on a chip-by-chip basis to see if I can isolate one or more chips that is causing the problem. Does this seem like a good idea? My thought is to cut as few traces as possible and to also keep the load on the buffers consistent through the testing. Do I also need to break nCONFIG to keep a chip from triggering a global fail? Any ideas are much appreciated! Thanks, -Nick.
