17 years agoCyclone III EPCS16 config FAIL
Hi all, I'm working on a revision of a PCB that contains a total of 12 EP3C16Q240C8N all configured with the same object file as in figure 10-6 of the datasheet. As it stands now, the configur...
17 years agoHey Guys,
Just wanted to check, do you have CONF_DONE hooked up to a 10K pull-up resistor? Just wanted to make sure before people start throwing crazy suggestions your way. Good luck! Chris
