17 years agoCyclone III EPCS16 config FAIL
Hi all, I'm working on a revision of a PCB that contains a total of 12 EP3C16Q240C8N all configured with the same object file as in figure 10-6 of the datasheet. As it stands now, the configur...
17 years agoHi Nick,
Have you found a solution yet? I'm having a similar problem when configuring in AS mode via an EPCS16, where nstatus is pulling low as conf_done rises. This is using a stratix2gx with AES encryption key programmed. The FPGA does boot however when I leave the ethernet blaster cable connected (I mean physically just the cable, not the programmer!) Fitting a capacitor of between 66pF and 330pF between conf_done and GND is allowing the FPGA to boot without the cable fitted, just need to know why now! Let me know if you've found anything different. Cheers Andrew
