17 years agoCyclone III EPCS16 config FAIL
Hi all, I'm working on a revision of a PCB that contains a total of 12 EP3C16Q240C8N all configured with the same object file as in figure 10-6 of the datasheet. As it stands now, the configur...
17 years agoI am having a similiar problem. When I power up my board, the nStatus line settles at about 0.9V. When I try and configure the device (3C16 and 3C80), the Config_Done line goes to about 1V for a few milliseconds, then drops to 0V. If I replace the 10K pullups on nStatus and Config_Done to 4.7K, the board works fine.
Regards, Phil Reum
