17 years agoCyclone III EPCS16 config FAIL
Hi all, I'm working on a revision of a PCB that contains a total of 12 EP3C16Q240C8N all configured with the same object file as in figure 10-6 of the datasheet. As it stands now, the configur...
17 years ago --- Quote Start --- Jay, I required a pullup on both done and nstatus. The device would configure with just the 4.7K on the done line, but the nstatus was still "stuck" at ~0.9V. Phil --- Quote End --- Hmmm, diode drop? I'm curious, what is the voltage on the bank with the nstatus pin? How about the pull-up voltage on the done line?
