17 years agoCyclone III EPCS16 config FAIL
Hi all, I'm working on a revision of a PCB that contains a total of 12 EP3C16Q240C8N all configured with the same object file as in figure 10-6 of the datasheet. As it stands now, the configur...
17 years agoPhil, thanks for the response. If you know, did a pull-up change on just the Conf_Done resolve this for you or did you have to change the value for both Conf_Done and nStatus? I may ask an FAE out this way to ping the factory about how this operates on the CIII. And, if the timing has changed.
