francisco-padilla-ed
3 months agoCyclone 10 LP I/O pins configuration
Hello, I am working with a custom PCB that includes a Cyclone 10 LP FPGA, and I am using Quartus Prime Lite v20.1.1. On this PCB, some of the output pins drive optical fibers. The problem is that, ...
- 3 months ago
Hi Francisco,
pin options become active after loading configuration bistreams. In unconfigured state, FPGA IO pins are still driven by weak pull-up and can produce unwanted output signals.
There are two ways to overcome the situation:
- Change logic polarity to active-low
- Use strong pull-down resistors (e.g. 0.5 - 1k) to override pull-up.
Regards Frank
AqidAyman_Altera
3 months agoYes, FvM is correct. You can refer to this configuration sequence where the I/O pins are tied to an internal weak pull-up when the device is powered on.
3 months agoHello,
Thanks FvM and AqidAyman_Altera for your replies. Using 1k pull-down resistors solved our problem.
Francisco
