francisco-padilla-ed's avatar
3 months ago
Cyclone 10 LP I/O pins configuration
Hello, I am working with a custom PCB that includes a Cyclone 10 LP FPGA, and I am using Quartus Prime Lite v20.1.1. On this PCB, some of the output pins drive optical fibers. The problem is that, ...
  • FvM's avatar
    3 months ago
    Hi Francisco,
    pin options become active after loading configuration bistreams. In unconfigured state, FPGA IO pins are still driven by weak pull-up and can produce unwanted output signals.
    There are two ways to overcome the situation:
    • Change logic polarity to active-low
    • Use strong pull-down resistors (e.g. 0.5 - 1k) to override pull-up.
    Regards Frank
