I_like_leds_15's avatar
I_like_leds_15
3 months ago
Cyclone 10 LP Error Detection Timing
I am working with the cyclone 10 LP FPGA dev board from Altera.
I am trying to get the error detection block working during configuration. I have followed this guide: accessing-error-detection-block-through-user-logic-cyclone-10-lp
I have added the cyclone 10 lp components library and was able to instantiate this WYSIWYG atom:
-- cyclone10lp_crcblock parameterized megafunction component declaration
-- Generated with 'mega_defn_creator' loader - do not edit
component cyclone10lp_crcblock
  generic (
      lpm_hint    :   string := "UNUSED";
      lpm_type    :   string := "cyclone10lp_crcblock";
      oscillator_divider  :   natural := 1    );
  port(
      clk :   in std_logic := '0';
      crcerror    :   out std_logic;
      ldsrc   :   in std_logic := '0';
      regout  :   out std_logic;
      shiftnld    :   in std_logic := '0'
end component;
The crc block shows up in the technology map, and I am able to shift out the pre-calculated CRC and CRC result (depending on the ldsrc value) using the regout port. the CRC_ERROR pin is also working correctly.
The timing is not working correctly. Regardless of the internal oscillator divisor setting, the time from INIT_DONE pin going high to CRC_ERROR pin going low is ~240 ms. I have tried changing the divisor setting in the quartus GUI, as well as in the generic map during instantiation. I was careful to make sure both matched, however even a divisor value of 256 does not change the timing at all.
According to this CRC error detection timing table, the time should be between 9 ms and 4.51 s for the 10CL025 device on the dev kit (depending on oscillator divisor).
Why am I not getting any time change when I change the oscillator divisor?
I have tried in both Quartus 24.1 STD and 25.1 STD
  • Hello,
    The oscillator_divider generic does not change the CRC engine's clock. CRC is clocked by internal configuration oscillator.
    Instead, set the clock in device option.
    Device and Pin option -> Error Detection CRC -> "Divide error check frequency by"(this will impact the internal configuration oscillator that clocks the CRC engine. Valid values are power of 2. Below is the .qsf example :
    set_global_assignment -name ERROR_CHECK_FREQUENCY_DIVISOR <2|4|8|...|256>
    regards,
    Farabi
  • Farabi's avatar
    Farabi
    regards,
    Farabi
  • I would like to clarify an error in my post,
    I am measuring the time from power on to CRC_ERROR going low. This time measurement is approximately 240 ms no matter what the divisor is.
    • Farabi's avatar
      Farabi
      Let me check the issue and get back to you.
      regards,
      Farabi
