I_like_leds_15
6 months agoCyclone 10 LP Error Detection Timing
I am working with the cyclone 10 LP FPGA dev board from Altera. I am trying to get the error detection block working during configuration. I have followed this guide: accessing-error-detection-bloc...
- 6 months ago
The oscillator_divider generic does not change the CRC engine's clock. CRC is clocked by internal configuration oscillator.
Instead, set the clock in device option.
Device and Pin option -> Error Detection CRC -> "Divide error check frequency by"(this will impact the internal configuration oscillator that clocks the CRC engine. Valid values are power of 2. Below is the .qsf example :
set_global_assignment -name ERROR_CHECK_FREQUENCY_DIVISOR <2|4|8|...|256>
regards,
Farabi
I_like_leds_15
6 months agoI would like to clarify an error in my post,
I am measuring the time from power on to CRC_ERROR going low. This time measurement is approximately 240 ms no matter what the divisor is.
- Farabi_Altera6 months ago
Let me check the issue and get back to you.
regards,
Farabi
