14 years ago
Create IRQ pin
On my design i have 2 processor, and i need to make for every one 2 pin( 1 input and one output). And relate the output for CPU1 with input for CPU2, also the iput from the CPU 1 with output from CPU2.
My problem how can i relate with these pin as i mentionned.
    --- Quote Start ---
    Verilog:
    wire signal_cpu2_to_cpu1;
    wire signal_cpu1_to_cpu2;
    Nios_system inst1(
       .clk(your_clock),
        .reset_n(your_reset),
        .in_port_to_the_cpu1_pio_in(signal_cpu2_to_cpu1),
        .in_port_to_the_cpu2_pio_in(signal_cpu1_to_cpu2),
        .out_port_from_the_cpu1_pio_out(signal_cpu1_to_cpu2),
        .out_port_from_the_cpu2_pio_out(signal_cpu2_to_cpu1),
    VHDL:
    SIGNAL signal_cpu1_to_cpu2 : STD_LOGIC;
    SIGNAL signal_cpu2_to_cpu1 : STD_LOGIC;
    COMPONENT Nios_system
        PORT (
            clk : IN std_logic;
            reset_n : IN std_logic;
           in_port_to_the_cpu1_pio_in : IN std_logic;
           in_port_to_the_cpu2_pio_in : IN std_logic;
           out_port_from_the_cpu1_pio_out : OUT std_logic;
           out_port_from_the_cpu2_pio_out : OUT std_logic;
    END COMPONENT;
    inst1 : Nios_system
    PORT MAP  (
            clk >= your_clk,
            reset_n >= your_reset,
           in_port_to_the_cpu1_pio_in >= signal_cpu2_to_cpu1;
           in_port_to_the_cpu2_pio_in >= signal_cpu1_to_cpu2;
           out_port_from_the_cpu1_pio_out  >= signal_cpu1_to_cpu2;
           out_port_from_the_cpu2_pio_out  >= signal_cpu2_to_cpu1;
    --- Quote End ---
    It work cris72 thank you.
    Verilog:
    Nios_system inst1(
       .clk(your_clock),
    VHDL:
        PORT (
            clk : IN std_logic;
    END COMPONENT;
    inst1 : Nios_system
    PORT MAP  (
            clk >= your_clk,
    --- Quote Start ---
    If you instantiate the system in a schematic, connect outputs to inputs with a wire. If you instantiate in HDL, write the assignement code for PIO port signals.
    --- Quote End ---
    Ok i will try to release it but can you give me an example code assignement, because whem i try to assigne the output and input to the same pin assignement, there are a code error that isn't possible to connect two pin the same pin assignement.
    I was thinking now that probably you can make everything inside sopc system, using only two PIOs, bidirectional, 1 bit wide. Each PIO is written by one cpu (as output) and read (as input and/or IRQ) by the other cpu.
    You have to try; I've never done something like this, so I'm not sure it iwill work.
    Thank you for your reply;
    I create 4 pio 2 input and 2 output as mentionned on the attached file.
    --- Quote Start ---
    This requires you connect PIOs externally to your sopc/Qsys module.
    --- Quote End ---
    I presume your processors are Nios, then you can easily do it with PIOs.
    One processor drives a PIO output which is connected to a PIO input (and possibly an IRQ) on the other processor. Same for signaling in the opposite direction.
    I think you could also make everything inside the module, if your cpu1 directly asserts the irq signal for irq2 and viceversa, but I don't know if this is easy to implement: probably you need to define a custom component which is capable to assert irqs.
