14 years agoCreate IRQ pin
On my design i have 2 processor, and i need to make for every one 2 pin( 1 input and one output). And relate the output for CPU1 with input for CPU2, also the iput from the CPU 1 with output from CPU...
14 years agoVerilog:
wire signal_cpu2_to_cpu1;
wire signal_cpu1_to_cpu2;
Nios_system inst1(
.clk(your_clock),
.reset_n(your_reset),
.in_port_to_the_cpu1_pio_in(signal_cpu2_to_cpu1),
.in_port_to_the_cpu2_pio_in(signal_cpu1_to_cpu2),
.out_port_from_the_cpu1_pio_out(signal_cpu1_to_cpu2),
.out_port_from_the_cpu2_pio_out(signal_cpu2_to_cpu1),
VHDL: SIGNAL signal_cpu1_to_cpu2 : STD_LOGIC;
SIGNAL signal_cpu2_to_cpu1 : STD_LOGIC;
COMPONENT Nios_system
PORT (
clk : IN std_logic;
reset_n : IN std_logic;
in_port_to_the_cpu1_pio_in : IN std_logic;
in_port_to_the_cpu2_pio_in : IN std_logic;
out_port_from_the_cpu1_pio_out : OUT std_logic;
out_port_from_the_cpu2_pio_out : OUT std_logic;
END COMPONENT;
inst1 : Nios_system
PORT MAP (
clk >= your_clk,
reset_n >= your_reset,
in_port_to_the_cpu1_pio_in >= signal_cpu2_to_cpu1;
in_port_to_the_cpu2_pio_in >= signal_cpu1_to_cpu2;
out_port_from_the_cpu1_pio_out >= signal_cpu1_to_cpu2;
out_port_from_the_cpu2_pio_out >= signal_cpu2_to_cpu1;
