14 years agoCreate IRQ pin
On my design i have 2 processor, and i need to make for every one 2 pin( 1 input and one output). And relate the output for CPU1 with input for CPU2, also the iput from the CPU 1 with output from CPU...
14 years ago --- Quote Start --- If you instantiate the system in a schematic, connect outputs to inputs with a wire. If you instantiate in HDL, write the assignement code for PIO port signals. --- Quote End --- Ok i will try to release it but can you give me an example code assignement, because whem i try to assigne the output and input to the same pin assignement, there are a code error that isn't possible to connect two pin the same pin assignement.
