14 years agoCreate IRQ pin
On my design i have 2 processor, and i need to make for every one 2 pin( 1 input and one output). And relate the output for CPU1 with input for CPU2, also the iput from the CPU 1 with output from CPU...
14 years agoThank you for your reply;
I create 4 pio 2 input and 2 output as mentionned on the attached file. --- Quote Start --- This requires you connect PIOs externally to your sopc/Qsys module. --- Quote End --- My problem is here is how can i connect the pin externally as you said
