18 years ago
Counting on falling and rising edge of clock
hi is it possible to design
dual edge counter in altera , what which is possible in xilinx cool runner series
reagards
baba
-- Xilinx ---
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_arith.all;
entity CNT2 is
port( data : in STD_LOGIC_VECTOR (1 downto 0); -- Parallel data in
cnt_en : in STD_LOGIC; -- Count enable
load : in STD_LOGIC; -- Load line enable
clr : in STD_LOGIC; -- Active low clear
clk : in STD_LOGIC; -- Clock
qout : inout STD_LOGIC_VECTOR (1 downto 0));
end CNT2;
architecture rtl of CNT2 is
signal q_int : UNSIGNED (1 downto 0);
begin
process(clk, clr)
begin -- Clear output register
if (clr = '0') then q_int <= (others => '0');-- Counting on falling and rising edge of clock
elsif clk'event then
if (load = '1') then q_int <= UNSIGNED(data);-- Load in start value
elsif cnt_en = '1' then q_int <= q_int + 1;-- If count enable is high
end if;
end if;
end process;
qout <= STD_LOGIC_VECTOR(q_int);
end rtl;
-- Altera i changed it like this --
library IEEE;
use IEEE.STD_LOGIC_1164.all;
use IEEE.STD_LOGIC_arith.all;
use IEEE.STD_LOGIC_unsigned.all;
entity dual is
port( cnt_en : in STD_LOGIC;
data : in STD_LOGIC_VECTOR (7 downto 0);
clr : in STD_LOGIC;
clk : in STD_LOGIC;
qout : inout STD_LOGIC_VECTOR (7 downto 0));
end dual;
architecture rtl of dual is
signal q_int_o,q_int_e : UNSIGNED (7 downto 0);
begin
process(clk, clr)
begin
if (clr = '0') then q_int_o <= "00000001";
elsif clk'event and clk='1' then
if data(0) ='1' then q_int_o <= UNSIGNED(data);
else q_int_o <= UNSIGNED(data)+1;
end if;-- Load in start value
elsif cnt_en = '1' then q_int_o <= q_int_o + 2;-- If count enable is high
end if;
end if;
end process;
process(clk, clr)
begin
if (clr = '0') then q_int_e <= (others => '0');
elsif clk'event and clk='0' then
if data(0) ='0' then q_int_e <= UNSIGNED(data);
else q_int_e <= UNSIGNED(data)-1;
end if;
elsif cnt_en = '1' then q_int_e <= q_int_e + 2;end if;
end if;
end process;
qout <= STD_LOGIC_VECTOR(q_int_e) when clk='0' else STD_LOGIC_VECTOR(q_int_o) when clk='1';
end rtl;
    You could use a circuit , which doubles the frequency. Xilinx has it online on their sites AFAIK. The circuit produces a small spike at every signal edge. This should do.
    Ahh, I didn't know that. (I used to work for X, but that was before they acquired Coolrunner, so I don't know much about that family. I was pretty sure the rest didn't support that.). If that's what you're targeting, then you're probably looking at an Altera device that doesn't have a PLL in it. But if it's purely a counter, then the lowest bit is purely a reflection of the clock(or the inverse of it, depending when you start the counter). I'm guessing you need more than a counter to have rise+fall capabilities?
    How is this done in Xilinx? I had someone target this for V5 in ISE, and after cleaning up the errors(entity changes from CNT to CNT2, and RESET_ACTIVE is undefined), it errors out with "unsupported clock statement".
    If your device has a PLL, you can create a 2x clock and use that for the counter. If there isn't, you can have a counter that counts on the rising edge, and then add an LSB that is the inversion of the clock(This requires you to understand the timing analysis that occurs, and really depends on what this counter feeds and what you're actually trying to show...)
