12 years agoCounter1 "q" o/p needs to be fed into the ROM "A_address" input .... Please Help.
LIBRARY ieee;
USE ieee.std_logic_1164.all; LIBRARY lpm; USE lpm.lpm_components.all; LIBRARY altera_mf; USE altera_mf.all; ENTITY LPM_ROM_MEGAFUNCTION IS PORT( A_address :IN std_logic_vector (0 downto 0); Sclk, clock :IN std_logic; Data,q :OUT STD_LOGIC_VECTOR (0 DOWNTO 0)); END LPM_ROM_MEGAFUNCTION; Architecture Behavioural of LPM_ROM_MEGAFUNCTION is component Variation1 PORT ( address : IN STD_LOGIC_VECTOR (0 DOWNTO 0); clken : IN STD_LOGIC := '1'; clock : IN STD_LOGIC := '1'; q : OUT STD_LOGIC_VECTOR (0 DOWNTO 0) ); end component; component Counter1 PORT ( clock : IN STD_LOGIC ; updown : IN STD_LOGIC ; q : OUT STD_LOGIC_VECTOR (0 DOWNTO 0) ); end component; BEGIN rom_unit : variation1 PORT map ( address => A_address, clken => '1', clock => sclk, q => Data ); counter_unit : counter1 PORT map ( clock => clock, updown => '1', q => A_address ); End Behavioural; ====Dont konw what Im doing wrong here====Give me the following error message====Please Help==== Info: ******************************************************************* Info: Running Quartus II Analysis & Synthesis Info: Version 9.1 Build 350 03/24/2010 Service Pack 2 SJ Web Edition Info: Processing started: Sun Nov 03 21:55:54 2013 Info: Command: quartus_map --read_settings_files=on --write_settings_files=off LPM_ROM_MEGAFUNCTION -c LPM_ROM_MEGAFUNCTION Info: Found 2 design units, including 1 entities, in source file variation1.vhd Info: Found design unit 1: variation1-SYN Info: Found entity 1: Variation1 Info: Found 2 design units, including 1 entities, in source file lpm_rom_megafunction.vhd Info: Found design unit 1: LPM_ROM_MEGAFUNCTION-Behavioural Info: Found entity 1: LPM_ROM_MEGAFUNCTION Info: Found 2 design units, including 1 entities, in source file counter1.vhd Info: Found design unit 1: counter1-SYN Info: Found entity 1: Counter1 Error (10577): VHDL error at LPM_ROM_MEGAFUNCTION.vhd(51): actual port "A_address" of mode "in" cannot be associated with formal port "q" of mode "out" Error (10599): VHDL error at LPM_ROM_MEGAFUNCTION.vhd(51): can't update value of interface object "A_address" of mode IN Error: Quartus II Analysis & Synthesis was unsuccessful. 2 errors, 0 warnings Error: Peak virtual memory: 239 megabytes Error: Processing ended: Sun Nov 03 21:55:54 2013 Error: Elapsed time: 00:00:00 Error: Total CPU time (on all processors): 00:00:01 Error: Quartus II Full Compilation was unsuccessful. 4 errors, 0 warnings5 Replies
Hello ABlackBox.
I think you're trying to connect the output of the counter module ( q ) to the address of the rom_unit. To do this you should use an internal signal vector: signal int_address : std_logic_vector(WIDTH-1 downto 0) -- I don't know how many bits the address needs. Declare the constant WIDTH or simply -- replace with a numeric value BEGIN rom_unit : variation1 PORT map ( address => int_address, clken => '1', clock => sclk, q => Data ); counter_unit : counter1 PORT map ( clock => clock, updown => '1', q => int_address ); End Behavioural; I declare int_address between "architecture" and "begin". You have A_address as an input on top level entity. Do you really need it? - Altera_Forum
Hi Bertulus,
Thanks for you Reply, I will try this code now and let you know, also I don't really need A_address I just used it to make different then the address in the rest of the code "component Variation1" uses address. but yeah I would give this a go and get back to let you know :) Thanks a mill. - Altera_Forum
LIBRARY ieee;
USE ieee.std_logic_1164.all; LIBRARY lpm; USE lpm.lpm_components.all; LIBRARY altera_mf; USE altera_mf.all; ENTITY LPM_ROM_MEGAFUNCTION IS PORT( A_address :IN std_logic_vector (0 downto 0); Sclk, clock :IN std_logic; Data,q :OUT STD_LOGIC_VECTOR (0 DOWNTO 0)); END LPM_ROM_MEGAFUNCTION; Architecture Behavioural of LPM_ROM_MEGAFUNCTION is component Variation1 PORT ( address : IN STD_LOGIC_VECTOR (0 DOWNTO 0); clken : IN STD_LOGIC := '1'; clock : IN STD_LOGIC := '1'; q : OUT STD_LOGIC_VECTOR (0 DOWNTO 0) ); end component; component Counter1 PORT ( clock : IN STD_LOGIC ; updown : IN STD_LOGIC ; q : OUT STD_LOGIC_VECTOR (0 DOWNTO 0) ); end component; -- std_logic_vector(WIDTH-1 downto 0) -- I don't know how many bits the address needs. Declare the constant WIDTH or simply -- replace with a numeric value Signal int_address : std_logic_vector(0 downto 0); BEGIN rom_unit : variation1 PORT map ( address => int_address, clken => '1', clock => sclk, q => Data ); counter_unit : counter1 PORT map ( clock => clock, updown => '1', q=> int_address ); int_address => A_address; End Behavioural; ============================================================================================================ I have made the changes I have assigned a signal to q from the counter module and then fed that signal into the Rom Module compiler doesn't like it and returns the following: Info: ******************************************************************* Info: Running Quartus II Analysis & Synthesis Info: Version 9.1 Build 350 03/24/2010 Service Pack 2 SJ Web Edition Info: Processing started: Sun Nov 03 23:56:43 2013 Info: Command: quartus_map --read_settings_files=on --write_settings_files=off LPM_ROM_MEGAFUNCTION -c LPM_ROM_MEGAFUNCTION Info: Found 2 design units, including 1 entities, in source file variation1.vhd Info: Found design unit 1: variation1-SYN Info: Found entity 1: Variation1 Error (10500): VHDL syntax error at LPM_ROM_MEGAFUNCTION.vhd(60) near text "=>"; expecting "(", or "'", or "." Info: Found 0 design units, including 0 entities, in source file lpm_rom_megafunction.vhd Info: Found 2 design units, including 1 entities, in source file counter1.vhd Info: Found design unit 1: counter1-SYN Info: Found entity 1: Counter1 Error: Quartus II Analysis & Synthesis was unsuccessful. 1 error, 0 warnings Error: Peak virtual memory: 239 megabytes Error: Processing ended: Sun Nov 03 23:56:44 2013 Error: Elapsed time: 00:00:01 Error: Total CPU time (on all processors): 00:00:01 Error: Quartus II Full Compilation was unsuccessful. 3 errors, 0 warnings - Altera_Forum
Two things:
a-The error now is in the line: int_address => A_address; the assigment operator is <=. The corrected line is: int_address <= A_address; b-There will be an error again. The moduler counter_unit generate on its outputs the int_address vector. But you also receive this vector from outside of the top level entity ( A_address is an input to the circuit ). So you have a contention on signal int_address. May be you should use a multiplexor. In a special condition of the circuit you use the counter output, in other condition you use A_address. But this depends of how your circuit should behave. - Altera_Forum
I just figured the bus contention and for the time being I got rid of the A_address so I wouldn't require a multiplexor module, if I did require an external way of feeding in
A_address, I would go and implement it with a multiplexor module. Thank you so very much Bertulus, you are a star.
