12 years agoCounter1 "q" o/p needs to be fed into the ROM "A_address" input .... Please Help.
LIBRARY ieee; USE ieee.std_logic_1164.all; LIBRARY lpm; USE lpm.lpm_components.all; LIBRARY altera_mf; USE altera_mf.all; ENTITY LPM_ROM_MEGAFUNCTION IS PORT( A_address :IN std...
12 years agoI just figured the bus contention and for the time being I got rid of the A_address so I wouldn't require a multiplexor module, if I did require an external way of feeding in
A_address, I would go and implement it with a multiplexor module. Thank you so very much Bertulus, you are a star.
