12 years agoCounter1 "q" o/p needs to be fed into the ROM "A_address" input .... Please Help.
LIBRARY ieee; USE ieee.std_logic_1164.all; LIBRARY lpm; USE lpm.lpm_components.all; LIBRARY altera_mf; USE altera_mf.all; ENTITY LPM_ROM_MEGAFUNCTION IS PORT( A_address :IN std...
12 years agoTwo things:
a-The error now is in the line: int_address => A_address; the assigment operator is <=. The corrected line is: int_address <= A_address; b-There will be an error again. The moduler counter_unit generate on its outputs the int_address vector. But you also receive this vector from outside of the top level entity ( A_address is an input to the circuit ). So you have a contention on signal int_address. May be you should use a multiplexor. In a special condition of the circuit you use the counter output, in other condition you use A_address. But this depends of how your circuit should behave.
