12 years agoCounter1 "q" o/p needs to be fed into the ROM "A_address" input .... Please Help.
LIBRARY ieee; USE ieee.std_logic_1164.all; LIBRARY lpm; USE lpm.lpm_components.all; LIBRARY altera_mf; USE altera_mf.all; ENTITY LPM_ROM_MEGAFUNCTION IS PORT( A_address :IN std...
12 years agoHello ABlackBox.
I think you're trying to connect the output of the counter module ( q ) to the address of the rom_unit. To do this you should use an internal signal vector: signal int_address : std_logic_vector(WIDTH-1 downto 0) -- I don't know how many bits the address needs. Declare the constant WIDTH or simply -- replace with a numeric value BEGIN rom_unit : variation1 PORT map ( address => int_address, clken => '1', clock => sclk, q => Data ); counter_unit : counter1 PORT map ( clock => clock, updown => '1', q => int_address ); End Behavioural; I declare int_address between "architecture" and "begin". You have A_address as an input on top level entity. Do you really need it?
