10 years ago
clock mux, clock dividers and best clock constraints to use
hi,
i have a slow speed system as follows -
20M refclk -> clk divider giving refclk/2, refclk/4 -> clk_mux (to select clock going into rest of the syste) -> clk_gate -> ciock going into rest of the system
the clock divider, clk_mux, clk_gate are coded in verilog (they are not IPs in any way)
the above design leads to gates on the clock path, but i still have to implement the design as is and since its a slow speed design, i might be able to get away with the skew. so i had some questions regarding the best way of constraining the above design -
1) is it OK to constraint the clk divider outputs using the following syntax -
create_generated_clock -source [get_ports {refclk}] -divide_by 4 -multiply_by 1 [get_pins {clk_divider|DTC_CTSROOT_1|Q|q}]
create_generated_clock -source [get_ports {refclk}] -divide_by 2 -multiply_by 1 [get_pins {clk_divider|DTC_CTSROOT_2|Q|q}]
or should i use get_keepers in the constraint somewhere? is the above constraint wrong in anyway? Timequest does not throw an error by i've read that get_keepers should be used for this. is that correct?
2) is it OK to constraint the clk mux outputs using the following syntax (constraining the clk_mux output to the fastest/worst case frequency) -
create_generated_clock -source [get_ports {refclk}] -divide_by 2 -multiply_by 1 [get_pins {clk_mux_2to1|Z|combout}]
2a) when i use the above constraint, i get a warning in QuartusII saying - No paths exist between clock target "clk_mux_2to1|Z|combout" of clock "clk_mux_2to1|Z|combout" and its clock source. Assuming zero source clock latency.” why is this?
2b) my 2:1 clock mux is simply coded in verilog as - Z = sel? A0, A1 where Z is the output and A0, A1 are the clock inputs, sel is the select line for the mux
is the above method of constraint correct or do i need to use get_keepers in the constraint somewhere?
3) i know get_keepers returns a set of non-combinational nodes in the design. so is the get_keepers only applicable to clocked/registered logic? or should it be used to constraint combinatorial logic too?
4) since i have a clock gate in my design as well, is my understanding correct that i will need to constraint the clock gate output as well (to the worst case frequency output from the clk_gate)?
if so, can i simply use the constraint below or do i need to use get_keepers in here somewhere?
create_generated_clock -source [get_ports {refclk}] -divide_by 2 -multiply_by 1 [get_pins {clk_gate|out_clkt}]
please let me know ... thanks in advance ... :)
z.
    Zubin's generated clock for 4) looks correct except it's missing the -name. Note that -source is always a physical point in the design. You only need -master_clock if multiple clocks go through that point. For example, let's say you had two clocks coming in:
    create_clock -period 10.0 -name clk_A [get_ports {ref_clk_A}]
    create_clock -period 12.0 -name clk_B [get_ports {ref_clk_B}]
    And now let's say you build a 2:1 mux to gate them. To that mux output you would add:
    create_generated_clock -source [get_ports {ref_clk_A}] -name gate_clk_A [get_pins {clk_mux|combout}]
    create_generated_clock -source [get_ports {ref_clk_B}] -name gate_clk_B -add [get_pins {clk_mux|combout}]
    Now let's say the output of this fed another gated clock(please try to avoid this, just an example), then you would add something like:
    create_generated_clock -source [get_pins {clk_mux|combout}] -master_clock gate_clk_A -name gate_two_A [get_pins {clk_mux_two|combout}]
    (If it's a mux, you might have multiple constraints to this output, using the -add option)
    I am asking about the point 4) mentioned by Zubin. How should the create_generated_clock statement look like when I can not mention master clock as the refclk, but to mention it the output of the clk_mux
    Could you please clarify use of the last point 4).
    What kind of constraint is suitable for that last clock gate and how to write that.
    1) Looks good, but shouldn't there by a -name? Also, it seems like by 1 of DTC_CTSROOT would be the 10MHz clock and have a divide by 2, while bit 2 would be a divide by 1. I don't know what logic you have to divide down, but am just assuming it's a counter.
    2) This is wrong. There can't be a register between the -source and the target. You want your lines in 1) and then add:
    create_generated_clock -name clk5M -source [get_pins {clk_divider|DTC_CTSROOT_1|Q|q}] [get_pins {clk_mux_2to1|Z|combout}]
    create_generated_clock -name clk10M -source [get_pins {clk_divider|DTC_CTSROOT_2|Q|q}] [get_pins {clk_mux_2to1|Z|combout}] -add
    set_clock_groups -exclusive -group {clk5M} -group {clk10M}
    The last one cuts timing between these clocks, ensuring no paths are analyzed where clk5M drives the launch register and clk10M drives the latch, or vice-versa.
    get_keepers only does enpoints of a timing path, i.e. FFs, IO ports, RAMs, DSPs. Your use of get_pins works just as well and is necessary for the combinatorial mux output. There are multiple get_* commands that overlap in one way or another and when it makes sense, either one will work. get_pins is the one used by ASIC tools, but users often find it annoying(which is why it has things like -compatibility_mode, to make it work more like a simple wildcard to the name. The -hierarchical matching is confusing to most.
    Just to be safe, put a keep on your mux:
    (* keep *) wire Z;
    Quartus synthesis should preserve this anyway, but I've gotten in the habit of doing that.
