10 years agoclock mux, clock dividers and best clock constraints to use
hi, i have a slow speed system as follows - 20M refclk -> clk divider giving refclk/2, refclk/4 -> clk_mux (to select clock going into rest of the syste) -> clk_gate -> ciock going into rest ...
8 years agoZubin's generated clock for 4) looks correct except it's missing the -name. Note that -source is always a physical point in the design. You only need -master_clock if multiple clocks go through that point. For example, let's say you had two clocks coming in:
create_clock -period 10.0 -name clk_A [get_ports {ref_clk_A}] create_clock -period 12.0 -name clk_B [get_ports {ref_clk_B}] And now let's say you build a 2:1 mux to gate them. To that mux output you would add: create_generated_clock -source [get_ports {ref_clk_A}] -name gate_clk_A [get_pins {clk_mux|combout}] create_generated_clock -source [get_ports {ref_clk_B}] -name gate_clk_B -add [get_pins {clk_mux|combout}] Now let's say the output of this fed another gated clock(please try to avoid this, just an example), then you would add something like: create_generated_clock -source [get_pins {clk_mux|combout}] -master_clock gate_clk_A -name gate_two_A [get_pins {clk_mux_two|combout}] (If it's a mux, you might have multiple constraints to this output, using the -add option)
