14 years ago
Can someone please help me get this to compile
I can get this to compile and ive been at it for two days I dont get it
Can someone please help me to find why it wont compile.
The issue seems to be from the top If condition that uses SIGNAL_in and A_reg;
If i comment that sensativity list out and that correspsonding of condition it will compile
Its just a counter that has signals that go in and out of it from other counters.
The SIGNAL_IN is a reg type from the counter stacked on top of it. The error is only in this .v file not the other counter.
Please help im pulling my hair out.
module last_row_counter(A,OVERFLOW,CLK,RST, upcount,SIGNAL,SIGNAL_IN);
input wire CLK, RST, upcount;
input wire SIGNAL_IN;
output wire OVERFLOW;
output wire  A;
output wire SIGNAL;
reg OVERFLOW_reg;
reg  A_reg;
reg SIGNAL_reg;
assign SIGNAL=SIGNAL_reg;
assign A=A_reg;
assign OVERFLOW=OVERFLOW_reg;
always @ (posedge CLK or negedge RST)
begin
if (SIGNAL_IN==4'b0100 && A_reg== 4'b0010)
begin
A_reg<=4'b0000;
SIGNAL_reg<=4'b0000;
end
end
if (~RST) begin
 OVERFLOW_reg <= 1'b0;
 A_reg<= 4'b0000;
end
else if ( upcount == 1 )
 begin
 if (A<9) begin
   A_reg <= A_reg + 1'b1;
 SIGNAL_reg<=SIGNAL_reg+1'b1;
  end
  else begin
   A_reg <= 4'b0000;
  OVERFLOW_reg <= 1'b1;
  end
 end
 else
 begin
 if (A>2) begin  //This is my count down
  A_reg <= A_reg - 1'b1;
 end
 else begin
  A_reg <= 4'b1001;
  end
 end
endmodule
    Is the error message the same?
    Now you have a new error in that you are starting with an else if instead of just and if.
    Then the secondary if is not in the always block. (because no else condition on the reset)
    Things to try: Add more () to the code:
    double check begin end and if/else statements.
    try making it a sync reset block by removing the "or negedge RST" from the sensitivity list. (Although this shouldn't be the issue) with the async reset as the first statement.
    Try using bitwise and versus logical and "&" instead of "&&" in the if statement.
    use more () to insure no order of operation issue is the cause of your grief..
    IE
    if ((SIGNAL_IN==4'b0100) & (A_reg== 4'b0010))
    I rearanged it with the reset back up top
    Still no luck
    Thanks for the continued help
    output wire  A;
    output wire SIGNAL;
    reg OVERFLOW_reg;
    reg  A_reg;
    reg SIGNAL_reg;
    assign A=A_reg;
    begin
    begin
    A_reg<=4'b0000;
    end
    end
    else if (~RST) //This is the main reset control*/
     begin
      A_reg<= 4'b0000;
     end
    if (SIGNAL_IN==4'b0100 && A_reg== 4'b0010) /*This Is where my input and output signal control should lie.
                   This is going To get a trigger from outside counter as a
                   refereance to where that counter is at.*/
     begin
      A_reg<=4'b0000;
     end
     else if ( upcount == 1'b1 ) //This is where the upcount starts
     begin
      if (A<2)
     begin
     end
      //This is to limit the counter. When the counter reaches its limitation in this case 2 it will reset to zero
      else
      begin
      A_reg <= 4'b0000;
      end
     end
     //This is the old downcount that has been turned off for now.
     /*else
     begin
     end
     else begin
      A_reg <= 4'b1001;
      end
     end
    endmodule
    --- Quote Start ---
    What's the exact error you are getting? On my previous post all the indenting got stripped away..
    The reset term should always be the first conditional especially since you are using an async reset.
    --- Quote End ---
    Everything works fine except for this line
    If i comment this line out it all works
    i need this line though.
    So if the reset needs to be first where do you suggest i put this line
    i just stuck it in there cuz the above someone receomended i needed to put it in the main always block
     begin
      A_reg<=4'b0000;
     end
    Also just a side note i have tried to put begin right under the sensitivity list and then again at the very bottom like you suggest
    still no change
    I thought that may be the issue but i the error is not with the begin and ends
    the compile error
    Error (10200): Verilog HDL Conditional Statement error at last_row_counter.v(37): cannot match operand(s) in the condition to the corresponding edges in the enclosing event control of the always construct
    On this line
    I went through all the begin and ends again i cannot not see any issue
    output wire  A;
    output wire SIGNAL;
    reg OVERFLOW_reg;
    reg  A_reg;
    reg SIGNAL_reg;
    assign A=A_reg;
    begin
    begin
    A_reg<=4'b0000;
    end
    end
     begin
      A_reg<=4'b0000;
     end
     begin
      A_reg<= 4'b0000;
     end
     begin
      if (A<2)
     begin
     end
      else
      begin
      A_reg <= 4'b0000;
      end
     end
     /*else
     begin
     end
     else begin
      A_reg <= 4'b1001;
      end
     end
    endmodule
    Now you have issues with your begin/end statements:
    Here's a clue.
    Write your code like this:
    always @(posedge CLK or negedge RST)
    begin
    if (~RST)
    begin
    end
    else
    begin
    if (statement)
    end
    end
    Here is a better version of with some added commments
    But as i said the problem only lies in one if clause with the SIGNAL_in && A-reg
    Hopefully someone can hep
    output wire  A;
    output wire SIGNAL;
    reg OVERFLOW_reg;
    reg  A_reg;
    reg SIGNAL_reg;
    assign A=A_reg;
    begin
    begin
    A_reg<=4'b0000;
    end
    end
     begin
      A_reg<=4'b0000;
     end
     begin
      A_reg<= 4'b0000;
     end
     begin
      if (A<2)
     begin
     end
      else
      begin
      A_reg <= 4'b0000;
      end
     end
     /*else
     begin
     end
     else begin
      A_reg <= 4'b1001;
      end
     end
    endmodule
    --- Quote Start ---
    One problem is you are assigning values to A_reg and SIGNAL_reg in multiple always blocks.
    You can use signals in different always blocks but you should always assign them in only one always block.
    Hope this helps
    Pete
    --- Quote End ---
    Hi Thanks Pete
    I put inside of one always block and still no luck
    Here is what it looks like now
    output wire  A;
    output wire SIGNAL;
    reg OVERFLOW_reg;
    reg  A_reg;
    reg SIGNAL_reg;
    assign A=A_reg;
    begin
    begin
    A_reg<=4'b0000;
    end
    end
    begin
    A_reg<=4'b0000;
    end
    if (~RST)
    begin
     A_reg<= 4'b0000;
    end
     begin
     if (A<9) begin
      end
      else begin
       A_reg <= 4'b0000;
      end
     end
     else
     begin
     end
     else begin
      A_reg <= 4'b1001;
      end
     end
    endmodule
    Hope this helps
    Pete
