14 years agoCan someone please help me get this to compile
I can get this to compile and ive been at it for two days I dont get it Can someone please help me to find why it wont compile. The issue seems to be from the top If condition that uses ...
14 years agoI thought that may be the issue but i the error is not with the begin and ends
the compile error Error (10200): Verilog HDL Conditional Statement error at last_row_counter.v(37): cannot match operand(s) in the condition to the corresponding edges in the enclosing event control of the always construct On this line if (SIGNAL_IN==4'b0100 && A_reg== 4'b0010) I went through all the begin and ends again i cannot not see any issuemodule last_row_counter(A,OVERFLOW,CLK,RST, upcount,SIGNAL,SIGNAL_IN);
input wire CLK, RST, upcount;
input wire SIGNAL_IN;
output wire OVERFLOW;
output wire A;
output wire SIGNAL;
reg OVERFLOW_reg;
reg A_reg;
reg SIGNAL_reg;
assign SIGNAL=SIGNAL_reg;
assign A=A_reg;
assign OVERFLOW=OVERFLOW_reg;
always @ (posedge CLK or negedge RST)
begin
begin
A_reg<=4'b0000;
SIGNAL_reg<=4'b0000;
end
end
if (SIGNAL_IN==4'b0100 && A_reg== 4'b0010) /*This Is where my input and output signal control should lie.
This is going To get a trigger from outside counter as a
refereance to where that counter is at.*/
begin
A_reg<=4'b0000;
end
else if (~RST) //This is the main reset control*/
begin
OVERFLOW_reg <= 1'b0;
A_reg<= 4'b0000;
end
else if ( upcount == 1'b1 ) //This is where the upcount starts
begin
if (A<2)
begin
A_reg <= A_reg + 1'b1;
SIGNAL_reg<=SIGNAL_reg+1'b1;
end
//This is to limit the counter. When the counter reaches its limitation in this case 2 it will reset to zero
else
begin
A_reg <= 4'b0000;
OVERFLOW_reg <= 1'b1;
end
end
//This is the old downcount that has been turned off for now.
/*else
begin
if (A>2) begin //This is my count down
A_reg <= A_reg - 1'b1;
end
else begin
A_reg <= 4'b1001;
end
end
endmodule
