14 years agoCan someone please help me get this to compile
I can get this to compile and ive been at it for two days I dont get it Can someone please help me to find why it wont compile. The issue seems to be from the top If condition that uses ...
14 years agoHere is a better version of with some added commments
But as i said the problem only lies in one if clause with the SIGNAL_in && A-reg Hopefully someone can hepmodule last_row_counter(A,OVERFLOW,CLK,RST, upcount,SIGNAL,SIGNAL_IN);
input wire CLK, RST, upcount;
input wire SIGNAL_IN;
output wire OVERFLOW;
output wire A;
output wire SIGNAL;
reg OVERFLOW_reg;
reg A_reg;
reg SIGNAL_reg;
assign SIGNAL=SIGNAL_reg;
assign A=A_reg;
assign OVERFLOW=OVERFLOW_reg;
always @ (posedge CLK or negedge RST)
begin
if (SIGNAL_IN==4'b0100 && A_reg== 4'b0010)
begin
A_reg<=4'b0000;
SIGNAL_reg<=4'b0000;
end
end
if (SIGNAL_IN==4'b0100 && A_reg== 4'b0010) /*This Is where my input and output signal control should lie.
This is going To get a trigger from outside counter as a
refereance to where that counter is at.*/
begin
A_reg<=4'b0000;
end
else if (~RST) //This is the main reset control*/
begin
OVERFLOW_reg <= 1'b0;
A_reg<= 4'b0000;
end
else if ( upcount == 1'b1 ) //This is where the upcount starts
begin
if (A<2)
begin
A_reg <= A_reg + 1'b1;
SIGNAL_reg<=SIGNAL_reg+1'b1;
end
//This is to limit the counter. When the counter reaches its limitation in this case 2 it will reset to zero
else
begin
A_reg <= 4'b0000;
OVERFLOW_reg <= 1'b1;
end
end
//This is the old downcount that has been turned off for now.
/*else
begin
if (A>2) begin //This is my count down
A_reg <= A_reg - 1'b1;
end
else begin
A_reg <= 4'b1001;
end
end
endmodule
