sleh
1 month agoAvalon-ST configuration with Agilex 3 fails
I have implemented a kind of passive serial programming from a CPU using SPI and a shift register. The signals nSTATUS, nCONFIG, CONF_DONE, READY, and VALID are directly controlled by GPIOs. This works well except after a power cycle. After the system has powered up, the programming fails — CONF_DONE does not go high. All retries afterward succeed. I already went through the debugging guidelines but couldn’t find an issue. However, I have observed two things:
- The nSTATUS pin follows exactly the timing of the nCONFIG pin during the first attempt. Normally, nSTATUS is delayed and goes high later.
- The CPU must finish the complete programming cycle before retrying; otherwise, the FPGA remains stuck in this erroneous state.
I recorded some curves with a logic analyzer:
- full_timing.png:
- Power cycle
- First configuration cycle fails
- Retry works
- Another cycle also works
- 2_start.png:
- Beginning of cycle 2. Here, the nSTATUS pin follows exactly the timing of the nCONFIG pin.
- 2_3_restart.png:
- End of cycle 2 and beginning of cycle 3.
- 4_start.png:
- Another configuration cycle that works.
Any idea what could cause this problem?
Regards Samuel
