Avalon-ST configuration with Agilex 3 fails
No screenshots were attached.
- sleh5 months ago
Let's hope it works this time.
- sleh5 months ago
I checked the power-up sequence again and made sure that no input is driven when the power is turned on. I have no idea what could be causing the programming problem.
Please help, Thanks
- FakhrulA_altera5 months ago
Hi sleh,
Could you share the screenshots of any error codes from the Quartus Programmer?
Please refer to this troubleshooting guideline: https://www.intel.com/content/www/us/en/support/programmable/support-resources/configuration/troubleshooting.html
Fakhrul- sleh5 months ago
Hi Fakhrul,
Thank you for the link. The Quartus programmer never reports an error when I program via JTAG.
The problem I have is that programming via AVST fails the first time after power-up. The FPGA already shows strange behavior at the beginning when nConfig goes low, see attached image. The nSTATUS pin follows the timing of nCONFIG exactly, which is abnormal. There must be an explanation for this.
