Firaseng's avatar
Firaseng
2 years ago
Alt for EP1K50TI144-2N
Hi All,
I need an alternative FPGA for the
EP1K50TI144-2N
That does not require major changes to the firmware code ,which family would easier to migrate to the obsolete
EPF10K10AQI208-3
or the MAX 10?
  • _AK6DN_'s avatar
    _AK6DN_
    2 years ago
    Nope, you are stuck with the EP1K50 series if all you have is a .pof file. Any temp grade, any speed grade will suffice.
    You need the source code to migrate to any other device (or even a different size of the EP1K series) to do a recompile.
    So unless you can come up with the source code you are going to be stuck sourcing EP1K50's from brokers.
  • NazrulNaim_Intel's avatar
    NazrulNaim_Intel
    Nazrul Naim
    NazrulNaim_Intel
    It has been a while since you last posted at this community forum. Do you have any further question regarding this case?
    Nazrul Naim
    • Firaseng's avatar
      Firaseng
      Hi Nazrul,
      I did finally locate the Verilog code for the FPGA on that project ,so in that case which FPGA may require the least amount of code changes ,Cyclone II or Max V? I am referring to any macros custom to that chip?
      • _AK6DN_'s avatar
        _AK6DN_
        Probably about the same for either target device, but it also depends upon what IP (if any) you have in your original verilog code.
        If it is mostly all your user written verilog, with may just PLL or I/O cell references, should be pretty easy to port.
        If you used some old IP block that no longer is available you will need to write code to replace it or find the current equivalent, if any.
        In any event having that verilog gives you a fighting chance of moving to a new device.
    NazrulNaim_Intel
    As user '_AK6DN_', You need the source code to migrate to any other device to do a recompile. Yes, it will also be the same as for EPM7064STI100-7 CPLD.
    Hope that answers your question.
    Nazrul Naim
  • givememessage's avatar
    givememessage
    As long as you can buy it, it's not a problem. The work of modifying the code is troublesome, and replacing the chip may not work.
    NazrulNaim_Intel
    Sorry for the delay, we highly recommend you use the latest device such as MAX10 or Cyclone 10 because if you are using old devices, the technical support for the device is really limited.
    Hope that helps and do let me know if I can assist you further.
    Nazrul Naim
    • Firaseng's avatar
      Firaseng
      I only have the .pof code for my EP1K50TI144-2N,no source code,would I be able to go to a MAX10 without much issues?
      • _AK6DN_'s avatar
        _AK6DN_
    • FvM's avatar
      FvM
      Surely you'll go for MAX 10, only problem could be missing 5V tolerance of MAX 10 inputs.
      EPF10K is by the way a 5V device and can't replace 3.3 V ACEX 1 series.
      • Firaseng's avatar
        Firaseng
        Hi FvM,
        While my FPGA on the board is using 2.5 and 3.3 v ,I am able to source both 5 and 3.3 V for the inputs, if need be ,they are available on the PCB,my concern is which of the 2 will require less code changes and schematic capture and layout rerouting.
