Firaseng
2 years agoAlt for EP1K50TI144-2N
Hi All, I need an alternative FPGA for the EP1K50TI144-2N That does not require major changes to the firmware code ,which family would easier to migrate to the obsolete EPF10K10AQI208-...
- 2 years ago
Nope, you are stuck with the EP1K50 series if all you have is a .pof file. Any temp grade, any speed grade will suffice.
You need the source code to migrate to any other device (or even a different size of the EP1K series) to do a recompile.
So unless you can come up with the source code you are going to be stuck sourcing EP1K50's from brokers.
NazrulNaim_Intel
2 years agoHello,
It has been a while since you last posted at this community forum. Do you have any further question regarding this case?
Nazrul Naim
