Alt for EP1K50TI144-2N
- 2 years ago
Nope, you are stuck with the EP1K50 series if all you have is a .pof file. Any temp grade, any speed grade will suffice.
You need the source code to migrate to any other device (or even a different size of the EP1K series) to do a recompile.
So unless you can come up with the source code you are going to be stuck sourcing EP1K50's from brokers.
EPF10K is by the way a 5V device and can't replace 3.3 V ACEX 1 series.
Hi FvM,
While my FPGA on the board is using 2.5 and 3.3 v ,I am able to source both 5 and 3.3 V for the inputs, if need be ,they are available on the PCB,my concern is which of the 2 will require less code changes and schematic capture and layout rerouting.
- givememessage2 years ago
Since EP1K50TI144-2N is in stock, why does it need to be modified? Replacing it is a very painful thing
- Firaseng2 years ago
Microchip offers a very similar FPGA but it would probably still be a good bit of work.
I am actually trying to avoid replacing the chip but its obsolete and can only be purchased from brokers.
- J2Damir2 years ago
Hi
I can sell 670 pcs of the EP1K50TI144-2N. DC: 2017+. New and original.
If you are interested in a full offer please email me at :
Br
Damir
