Alt for EP1K50TI144-2N
- 2 years ago
Nope, you are stuck with the EP1K50 series if all you have is a .pof file. Any temp grade, any speed grade will suffice.
You need the source code to migrate to any other device (or even a different size of the EP1K series) to do a recompile.
So unless you can come up with the source code you are going to be stuck sourcing EP1K50's from brokers.
EP1K50TI144-2N and
EPF10K10AQI208-3 is still in stock
Email:[email protected]
- FvM2 years ago
Surely you'll go for MAX 10, only problem could be missing 5V tolerance of MAX 10 inputs.
EPF10K is by the way a 5V device and can't replace 3.3 V ACEX 1 series.- Firaseng2 years ago
Hi FvM,
While my FPGA on the board is using 2.5 and 3.3 v ,I am able to source both 5 and 3.3 V for the inputs, if need be ,they are available on the PCB,my concern is which of the 2 will require less code changes and schematic capture and layout rerouting.
- givememessage2 years ago
Since EP1K50TI144-2N is in stock, why does it need to be modified? Replacing it is a very painful thing
