Alt for EP1K50TI144-2N
- 2 years ago
Nope, you are stuck with the EP1K50 series if all you have is a .pof file. Any temp grade, any speed grade will suffice.
You need the source code to migrate to any other device (or even a different size of the EP1K series) to do a recompile.
So unless you can come up with the source code you are going to be stuck sourcing EP1K50's from brokers.
Sorry for the delay, we highly recommend you use the latest device such as MAX10 or Cyclone 10 because if you are using old devices, the technical support for the device is really limited.
Hope that helps and do let me know if I can assist you further.
Nazrul Naim
- Firaseng2 years ago
I only have the .pof code for my EP1K50TI144-2N,no source code,would I be able to go to a MAX10 without much issues?
- _AK6DN_2 years ago
Hello again,
Is that also the case for the
EPM7064STI100-7 CPLD?
