Agilex7i devkit - device not support reconfiguration with factory SDM helper image
i'm using DK-DEV-AGI027RBES devkit, The board switches are configured as follows, trying to refresh the Agilex7i *.jic file using my design with hps. A while ago i flashed a golden reference *jic via an embedded jtag (J8) and see yocto boot. The same ghrd *.jic reprogramming is blocked by some devices in the JTAG chain. Can you provide steps on how to reprogram *.jic/ghrd *.jic?
SW1=ON/Off/Off/Off;
SW2=ON/Off/Off/Off;
SW3=Off/ON/ON/Off;
SW4=Off/Off/ON/Off;
SW5=Off/Off/Off/Off;
SW8=Off/Off/Off/Off
NOTE: I tried flashing the GHRD *.JIC using the devkit embedded USB blaster and I saw the same popup and stopped me from loading the JIC.
Also, although *.sof is being programmed, "Error (20064): Error status: Unable to set chip select" always appears. What does it mean? Why am I getting this error?
Shivaji M
