Agilex 7 F Series Transceiver Pins Allowed Voltages During Powerup/When Unpowered
- 6 months ago
Yes, there is no footnote about the refclk but they can be driven when unpowered as long as there is proper coupling and the voltages are in the specified limits.
Thank you for the link. Below image is what I see regarding hot plug. It states that the device supports addition/removal from system during run-time.
I am not sure if this means Hot Plug is supported functionally but assumes the hardware design prevents I/O from being toggled while device is now powered by for example gating the I/O by having an enable for the REF_CLK buffer that is tied to the Agilex power supplies "Power Sequence Done" signal or similar.
Can you please confirm Agilex7 F tile transceivers will not be damaged when Agilex 7 F tile hot plugged into system with like PCIe REF_CLK and PCIE data lines such that they are driven before the Agilex7 F tile is powered.
