Agilex 5 LVDS reciver with custom pins
inverted pins of differential pairs are assigned automatically by the fitter, you don't need to enter it in pin planner. Does the error also come up if you only assign p-pins?
As you pointed, leaving the n-pins unassigned seem the fitter associate them automatically to their complementary ones.
However, we are allowed to direclty assingn the n-pins from lane 1 without any issue but not the ones belonging to lane 2 as the following image shows
We would like to know what is the reason why one lane allows direct assign and the other no. Both lanes belong to the same HSIO bank. In the case shown in the image, would all LVDS lanes work properly?
Thanks in advance
- AqidAyman_Altera2 months ago
After you followed the guidelines, are you still observing the issue on the pins in Lane 2 that are not directly assigned to their associated complementary pins?
Aqid
- K_ED_RD12 months ago
We have been following the guidelines. The LVDS receiver IP is configured as shown in the initial post, we tried to only assingn the positive pins or both positive ang negative, but it does not work for pins on lane 2.
Best regards
Thank you for the confirmation. May I know if you are okay to provide your design file or a simple design where it demonstrate the issue you are facing?
I would like to reproduce the issue from my side.
Let me know if you wanted to share it privately.
Aqid
