14 years ago
10G Ethernet and 10G Base-R PHY Hardware Demonstration Design
Hi all,
I am trying to test board-to-board communication using a complete 10G Ethernet design that includes an Altera 10 GbE MAC + an Altera 10GBASE-R IP cores. My devices are Stratix IV GT and my boards are two identical Transceiver Signal Integrity Development Kits (EP4S100G2F40I1). I found a hardware demonstration design from Altera Wiki:
http://www.alterawiki.com/wiki/10g_ethernet_and_10g_base_r_phy_interoperability_hardware_demonstration_design
This design is for different board (100G SIV GT Development Board). So, I have changed pin assignment, regenerate as well as recompile the design for my board. Finally, I could run the demo script to test several loopback modes.
My next plan is to test board-to-board communication with the two boards rather than looping back on the same board using the provided TCL scripts. As I am new to such task and there are a lot to grasp, I wonder where I should start to realize my purpose. So, if anyone has experience with this or similar designs, please give me a clue or some advice. Any help will be really appreciated.
Thanks for reading this thread.
    From your code:
    ETH10G_TOP  ETH10G_TOP (
        .mm_clk_clk                            (clk_50),
        .mm_reset_reset_n                    (RESET_N),
        .mm_pipeline_bridge_address            (slave_if_address),
        .mm_pipeline_bridge_waitrequest        (slave_if_waitrequest),
        .mm_pipeline_bridge_read            (slave_if_read),
        .mm_pipeline_bridge_readdata        (slave_if_readdata),
        .mm_pipeline_bridge_write            (slave_if_write),
        .mm_pipeline_bridge_writedata        (slave_if_writedata),
        .xgmii_rx_clk_clk                    (rx_phy_clk),
        .link_fault_status_xgmii_rx_data    (link_fault_status),
        .tx_serial_data_export                (TXP_10G_BASE_R),
        .rx_serial_data_export                (RXP_10G_BASE_R),
        .ref_clk_clk                        (REFCLK),
        .ref_reset_reset_n                    (RESET_N),
        .avalon_st_rxstatus_valid            (rx_status_valid),
        .avalon_st_rxstatus_data            (rx_status_data),
        .avalon_st_rxstatus_error            (rx_status_error),
        .avalon_st_txstatus_valid            (),
        .avalon_st_txstatus_data            (),
        .avalon_st_txstatus_error            (),
        .tx_ready_export                    (tx_pma_ready),
        .rx_ready_export                    (rx_pma_ready),
        .rx_sc_fifo_out_data                (avalon_st_rx_data),
        .rx_sc_fifo_out_valid                (avalon_st_rx_valid),
        .rx_sc_fifo_out_ready                (avalon_st_rx_ready),
        .rx_sc_fifo_out_startofpacket        (avalon_st_rx_sop),
        .rx_sc_fifo_out_endofpacket            (avalon_st_rx_eop),
        .rx_sc_fifo_out_empty                (avalon_st_rx_empty),
        .rx_sc_fifo_out_error                (avalon_st_rx_error),
        .tx_sc_fifo_in_data                    (avalon_st_tx_data),
        .tx_sc_fifo_in_valid                (avalon_st_tx_valid),
        .tx_sc_fifo_in_ready                (avalon_st_tx_ready),
        .tx_sc_fifo_in_startofpacket        (avalon_st_tx_sop),
        .tx_sc_fifo_in_endofpacket            (avalon_st_tx_eop),
        .tx_sc_fifo_in_empty                (avalon_st_tx_empty),
        .tx_sc_fifo_in_error                (avalon_st_tx_error),
        .mdio_mdc                           (mdc_from_the_mdio),
        .mdio_mdio_in                        (mdio_in_to_the_mdio),
        .mdio_mdio_out                        (mdio_out_from_the_mdio),
        .mdio_mdio_oen                       (mdio_oen_from_the_mdio),
        .tx_clk_clk                            (rx_phy_clk),
        .tx_reset_reset_n                    (RESET_N)
    There is both an MDIO interface and an Avalon slave interface. The slave should show up in your address map, and there should be registers for an MDIO controller (I assume this is an I2C controller that never actually exits the FPGA).
    Cheers,
    Dave
    You can check the Qsys system in the attachment. They use a Merlin Master Translator and there is only one Master-Slave connection here is between Merlin Master Translater->Eth_10g mm_pipeline_bridge (slave). I don't know why they do not use the Jtag to Avalon as a Master? What is the role of the Merlin Master Translator? is it used here like a Jtag to Avalon Master?
    In the scripts for hardware test, there are many base addresses for accessing. Many of those are not Qsys components.
    -- System Controller Base Address
    set GEN_BASE_ADDR 0x01000000
    set MON_BASE_ADDR 0x01040000
    set SYS_CTRL_LPBK_BASE_ADDR 0x01080000
    -- 10G Ethernet/10G Base R Design Example Base Address
    set 10GMAC_BASE_ADDR 0x00000000
    set PHY_IP_BASE_ADDR 0x00040000
    set MDIO_BASE_ADDR 0x00010000
    set XGMII_LB_BASE_ADDR 0x00010200
    set 10G_RX_FIFO_BASE_ADDR 0x00010400
    set 10G_TX_FIFO_BASE_ADDR 0x00010600
    Again, if they assign those manually or there is a tool for doing this automatically (like the "Assign Base Address" function in Qsys)?
    Dear Dave,
    I could make the board-to-board test run at receiver side without the "master_write_32" error.
    The monitor logic has a base address and several offsets for statistics:
    set MON_RXPKTCNT_EXPT 0x00000000
    set MON_RXPKTCNT_GOOD 0x00000004
    set MON_RXPKTCNT_BAD 0x00000008
    set MON_RXBYTECNT_LO32 0x0000000C
    set MON_RXBYTECNT_HI32 0x00000010
    set MON_RXCYCLCNT_LO32 0x00000014
    set MON_RXCYCLCNT_HI32 0x00000018
    set MON_RXCTRL_STATUS 0x0000001C
    set GEN_MON_LPBK 0x00000028
    I started generating and monitoring at both sides manually and almost at the same time. At RX side, the system console log shows that the monitor is unable to receive any packet. That means the above memory locations are not touched during the transmission. How can I explain and fix this? If you have any suggestion for debugging?
    Here is how the traffic controller works. The traffic generator at transmitter generates packets of different types, with random length(<=1518) and random payload then sends them in burst to receiver. The monitor at receiver just checks number of received packets, how many with errors, how many of each types,... In case I have a board-to-board test, my next step is to check the transmission, namely to compare the difference of data sent at TX and data received at RX. But, I still don't know whether packet contents are temporary stored somewhere at both sides or not. How do you think about this plan?
    Again, I need to understand the memory map. I could not find how the addresses are mapped and allocated in the design. I think this is a critical point for me now. Please help to give me a clue if possible.
    --- Quote Start ---
    --- Quote End ---
    My advice: You have the code in front of you. Look through it and understand it.
    If the example is too complicated, then stop looking at it, and work on something simpler. Go and listen to the SystemConsole webinar, go and create some simple designs that use SystemConsole, eg., the JTAG-to-Avalon-MM tutorial I wrote on the AlteraWiki. Basically, become comfortable with Qsys and Tcl. Then go back to the 10G problem.
    Cheers,
    Dave
    --- Quote Start ---
    --- Quote End ---
    Thanks for your advice. I am studying the code and learning System Console.
    Dear Dave,
    With my purpose of having a board-to-board 10GbE design, I have focused more in hardware test of the functionality of MAC or/and PHY layer. So, I have spent days to study this design (10G Ethernet and 10G Base-R PHY) and similar Altera reference designs such as:
    10-Gbps Ethernet Reference:
    http://www.altera.com/literature/ug/10g_ethernet_user_guide.pdf?gsa_pos=1&wt.oss_r=1&wt.oss=10-gbps%20ethernet%20reference%20design%20user%20guide
    10-Gbps Ethernet MAC and XAUI PHY Interoperability Hardware Demonstration:
    http://www.altera.com/literature/an/an638.pdf?gsa_pos=6&wt.oss_r=1&wt.oss=10-gbps%20ethernet%20reference%20design%20user%20guide
    Triple Speed Ethernet Data Path Reference Design:
    http://www.altera.com/literature/an/an483.pdf
    Stratix II GX 10GbE Loopback Reference Design
    http://www.altera.com/literature/an/an561.pdf
    And I found out that all the reference/example designs provided by Altera only support several loopback tests, either internal or local (external) loopback. While board-to-board testing is also necessary and more difficult (my personal thinking), Altera do not provide any demo tests. And so far, I even could not find related tutorials anywhere. How should we understand this situation? If you can share your opinion or suggest me a way to go on with my target design.
    Thank you very much.
    --- Quote Start ---
    --- Quote End ---
    You can't expect Altera to provide a reference for everything, they provide just enough to get you started.
    --- Quote Start ---
    --- Quote End ---
    The single-board reference design gives you everything you need to learn how to use the tools. You need to study the reference design until you can create that same design from scratch. Once you can do that, you have everything you need to create a dual-board design from scratch.
    If you think your solution would be useful to others, then please write a tutorial and post it to the Altera wiki.
    Cheers,
    Dave
