14 years ago10G Ethernet and 10G Base-R PHY Hardware Demonstration Design
Hi all, I am trying to test board-to-board communication using a complete 10G Ethernet design that includes an Altera 10 GbE MAC + an Altera 10GBASE-R IP cores. My devices are Stratix IV GT and...
14 years ago --- Quote Start --- Again, I need to understand the memory map. I could not find how the addresses are mapped and allocated in the design. I think this is a critical point for me now. Please help to give me a clue if possible. --- Quote End --- My advice: You have the code in front of you. Look through it and understand it. If the example is too complicated, then stop looking at it, and work on something simpler. Go and listen to the SystemConsole webinar, go and create some simple designs that use SystemConsole, eg., the JTAG-to-Avalon-MM tutorial I wrote on the AlteraWiki. Basically, become comfortable with Qsys and Tcl. Then go back to the 10G problem. Cheers, Dave
