14 years ago10G Ethernet and 10G Base-R PHY Hardware Demonstration Design
Hi all, I am trying to test board-to-board communication using a complete 10G Ethernet design that includes an Altera 10 GbE MAC + an Altera 10GBASE-R IP cores. My devices are Stratix IV GT and...
14 years agoFrom your code:
ETH10G_TOP ETH10G_TOP (
.mm_clk_clk (clk_50),
.mm_reset_reset_n (RESET_N),
.mm_pipeline_bridge_address (slave_if_address),
.mm_pipeline_bridge_waitrequest (slave_if_waitrequest),
.mm_pipeline_bridge_read (slave_if_read),
.mm_pipeline_bridge_readdata (slave_if_readdata),
.mm_pipeline_bridge_write (slave_if_write),
.mm_pipeline_bridge_writedata (slave_if_writedata),
.xgmii_rx_clk_clk (rx_phy_clk),
.link_fault_status_xgmii_rx_data (link_fault_status),
.tx_serial_data_export (TXP_10G_BASE_R),
.rx_serial_data_export (RXP_10G_BASE_R),
.ref_clk_clk (REFCLK),
.ref_reset_reset_n (RESET_N),
.avalon_st_rxstatus_valid (rx_status_valid),
.avalon_st_rxstatus_data (rx_status_data),
.avalon_st_rxstatus_error (rx_status_error),
.avalon_st_txstatus_valid (),
.avalon_st_txstatus_data (),
.avalon_st_txstatus_error (),
.tx_ready_export (tx_pma_ready),
.rx_ready_export (rx_pma_ready),
.rx_sc_fifo_out_data (avalon_st_rx_data),
.rx_sc_fifo_out_valid (avalon_st_rx_valid),
.rx_sc_fifo_out_ready (avalon_st_rx_ready),
.rx_sc_fifo_out_startofpacket (avalon_st_rx_sop),
.rx_sc_fifo_out_endofpacket (avalon_st_rx_eop),
.rx_sc_fifo_out_empty (avalon_st_rx_empty),
.rx_sc_fifo_out_error (avalon_st_rx_error),
.tx_sc_fifo_in_data (avalon_st_tx_data),
.tx_sc_fifo_in_valid (avalon_st_tx_valid),
.tx_sc_fifo_in_ready (avalon_st_tx_ready),
.tx_sc_fifo_in_startofpacket (avalon_st_tx_sop),
.tx_sc_fifo_in_endofpacket (avalon_st_tx_eop),
.tx_sc_fifo_in_empty (avalon_st_tx_empty),
.tx_sc_fifo_in_error (avalon_st_tx_error),
.mdio_mdc (mdc_from_the_mdio),
.mdio_mdio_in (mdio_in_to_the_mdio),
.mdio_mdio_out (mdio_out_from_the_mdio),
.mdio_mdio_oen (mdio_oen_from_the_mdio),
.tx_clk_clk (rx_phy_clk),
.tx_reset_reset_n (RESET_N)
There is both an MDIO interface and an Avalon slave interface. The slave should show up in your address map, and there should be registers for an MDIO controller (I assume this is an I2C controller that never actually exits the FPGA). Cheers, Dave
