Stratix IV GX Pin Assignment
I'm working on the Stratix IV GX 230 board and I'm trying to use the Triple Speed Ethernet in RGMII mode with MDIO. I did everything well untill the moment I needed the PIN in order to connect the MAC with the PHY. But I couldn't find any information concerning the following pin: For the MDIO: -mdio_oen -mdio_in -mdio_out -mdc For the RGMII: -tx_control_to_the_triple_speed_ethernet_0 -rx_controle_from_the_triple_speed_ethernet_0 -tx_clk_from_the_triple_speed_ethernet_0 -rx_clk_from_the_triple_speed_ethernet_0 -rgmii_in_from_the_triple_speed_ethernet_0 -rgmii_out_to_the_triple_speed_ethernet_0 All I could find was the PHY PIN assignment for the SGMII with LVDS transceiver there: http://www.altera.com/literature/manual/rm_sivgx_fpga_dev_board.pdf And even the documentation about the bank of IO couldn't tell more about that. Have anyone ever managed to use the RGMII with the Stratix IV in order to have an Ethernet output? Thank you. Michel28 Replies
Sure the FPGA is able to use the RGMII interface with the PHY, and so is the PHY, but from the schematic (page 13) you can see that the PHY's RGMII interface isn't connected, so you are stuck with SGMII on that board.
You should first ensure you have a correct MDIO communication with the PHY. The MDIO isn't used to transfer packets, but just to configure the PHY and get statistics. Once you have this, you know that the PHY is running. When checking the PHY's answer on the MDIO but, you must keep in mind that the TSE driver will try all the 32 possible PHY addresses, and will only get an answer on one of theme. Therefore you must either have a very big signaltap memory buffer to be sure to capture all the transactions, or trigger on something more special (such as mdio_oen at 1 and mdio_in at 0 at the some time, which would indicate a PHY communication). Once you can communicate with the PHY, you can focus on the SGMII interface again. When you have conflicting information about the pins between the user manual and the schematic, always trust the schematic. Bogus kit documentation is a recurring problem with Altera. - Altera_Forum
Thank you Daixiwen for your help,
Now that I put my signaltap to trigger on the mdio_oen = '1' and mdio_in = '0' I do have an answer coming from the PHY which is a small acknoledgement bit in the mdio_in. I guess my PHY is communicating with my TSE but what do you mean by focus on the SGMII again? I haven't done anything for the SGMII since I thought all the data coming out from the TSE were going to the PHY with the TX_p pin. I finally trusted the schematics and put the PIN_AC31 instead (anyway I had errors with the D31). - Altera_Forum
It's a good sign that you get an answer from the PHY. Does the software say it detected a PHY? Is it set in gigabit mode?
As for the SGMII interface you are right, the data goes to the PHY through the TX_p/TX_n pair and that's all that should matter. - Altera_Forum
The software doesn't say anything about detecting the PHY.
I haven't set it in Gigabit mode since I thought it was already set automatically by the TSE itself. Could you please tell me how to set the TSE in Gigabit mode please? - Altera_Forum
So this means there is still a communication problem on the MDIO line... could you put a screenshot of the MDIO communication, when the PHY responds?
For the gigabit mode I was talking about the PHY. Check if there is a led on the board that tells if the PHY is in gigabit mode. - Altera_Forum
Thank you Daixiwen, I have put a screenshot of my Signaltap in the following PDF (sorry I couldn't upload anything else because of the firewall)
Everytime I have my Simple_socket_server working I have the following messages: InterNiche Portable TCP/IP, v3.1 Copyright 1996-2008 by InterNiche Technologies. All rights reserved. prep_tse_mac 0 Can't read the MAC address from your board. We will assign you a MAC address. Please enter your 9-digit serial number. This is printed on a label under your Nios dev. board. The first 3 digits of the label are ASJ and the serial number follows this. -->Created "Inet main" task (Prio: 2) Created "clock tick" task (Prio: 3) 123456789 123456789 Your Ethernet MAC address is 00:07:ed:ff:cd:15 Static IP Address is 0.0.0.0 prepped 1 interface, initializing... [tse_mac_init] And since I'm using the PCIe port of my board (which is plugged on my motherboard) I can't really see LED blinking for the Gigabit Mode. But I'm quite sure that none of these LED are blinking. I also tried to disable the DHCP mode in my software but it comes to the same thing in the end. Again thank you for helping me. - Altera_Forum
Could you sample more bits, so that we can see the full message? You can use a slower clock to sample the bus, the MDIO clock is supposed to be <= 2.5MHz
I find it strange that the driver doesn't prinf anything about the PHY. And where does the 123456789 come from? Could you run the PHY exploring routine in a debugger, to see what it does? - Altera_Forum
The screenshot I made was a zoom of the sample, the MDIO clock for the signaltap is a 100MHz clock. But my TSE clock is a 150MHz clock and the MDIO host clock division is 60 for an MDIO clock of 2.5MHz.
I also find it strange that the driver doesn't printf anything about the PHY but I haven't changed anything about the software. The 123456789 comes from me since it's asking me to type my serial number, I've read the source code and it only generate a MAC ADDR according to this serial number, I don't think it really matters in this case. What do you mean by the PHY exploring routine? Do you want me to run the Simple_socket_server software in debug mode? - Altera_Forum
Well I did everything once again and this is what I get from the simple_socket_server_RGMII with the following options:
-DHCP disabled -TCP enabled The PIN used for the mdc and mdio_inout are the same than those used in the Altera niosii-triple-speed-ethernet-4sgx230-v10-1/tserd_4sgx230 design which are: enet_tx_p PIN_L29 enet_rx_p PIN_AC31 enet_mdc PIN_AH34 enet_mdio PIN_M33 I also changed the get_mac_addr() function to: int get_mac_addr(NET net, unsigned char mac_addr[6]) { error_t error = 0; mac_addr[0]=0xB7; mac_addr[1]=0xA7; mac_addr[2]=0xED; mac_addr[3]=0xFF; mac_addr[4]=0xFF; mac_addr[5]=0xFF; printf("Your Ethernet MAC address is %02x:%02x:%02x:%02x:%02x\n", mac_addr[0], mac_addr[1], mac_addr[2], mac_addr[3], mac_addr[4], mac_addr[5]); return error; } And when I run my software the message I got is: ************************************************************* InterNiche Portable TCP/IP, v3.1 Copyright 1996-2008 by InterNiche Technologies. All rights reserved. prep_tse_mac 0 Your Ethernet MAC address is b7:a7:ed:ff:ff:ff Static IP Address is 192.168.1.234 prepped 1 interface, initializing... [tse_mac_init] INFO : TSE MAC 0 found at address 0x00000400 ERROR : MAC Group[0] - No PHY connected! INFO : PCS[0.0] - Configuring PCS operating mode INFO : PCS[0.0] - PCS SGMII mode enabled ERROR : PHY[0.0] - No PHY connected! Speed = 100, Duplex = Full OK, x=0, CMD_CONFIG=0x00000000 MAC post-initialization: CMD_CONFIG=0x04000203 [tse_sgdma_read_init] RX descriptor chain desc (1 depth) created mctest init called IP address of et1 : 192.168.1.234 Created "Inet main" task (Prio: 2) Created "clock tick" task (Prio: 3) Simple Socket Server starting up [sss_task] Simple Socket Server listening on port 30 Created "simple socket server" task (Prio: 4) ***************************************************************** I also attached the signaltap screenshot. It seems that my PHY still doesn't work even if my MDIO get an answer coming from the PHY. Thank you - Altera_Forum
This message here
Says that without communication with the PHY, the driver automatically switched to 100Mbps mode. If the PHY has negotiated a link at 1Gbps, it won't work. Even if you forced the driver into gigabit mode I'm not sure it would work, as the PHY requires some initialization. The function that does the PHY detection is called alt_tse_mac_get_phy). It could be a good idea to run it step by step and see if it detects anything on the mdio bus. Looking back at your screenshot, I'm not sure what we are seeing is in fact an answer from the PHY. It could just be because of the delay before the pull-up brings the line back to a '1' level. If you look closer at tho code, you'll see that the driver tries all 32 PHY addresses, looking for an answer. One of them should show a different result on the MDIO line. Now I may sound stupid but you never know... Are you sure the ENET_RESETn signal isn't kept low by the FPGA?ERROR : PHY - No PHY connected! Speed = 100, Duplex = Full
