15 years agoStratix IV GX Pin Assignment
Hi, I'm working on the Stratix IV GX 230 board and I'm trying to use the Triple Speed Ethernet in RGMII mode with MDIO. I did everything well untill the moment I needed the PIN in order to co...
15 years agoIt's a good sign that you get an answer from the PHY. Does the software say it detected a PHY? Is it set in gigabit mode?
As for the SGMII interface you are right, the data goes to the PHY through the TX_p/TX_n pair and that's all that should matter.
